New Engine Question?
Originally Posted by 7th Darkness
So I was told that the LS1 motor compenents will not fit on to a 350 engine...is this true?
I have a blown engine looking to do a swap... any good places to get a new engine?
did you destroy the block or just destroy a piston/rod?
Well I am not sure what is damaged, but it will cost just as much to tear it down than to just replace drop and swap due to labor charges.
Basically what I am asking is if I got a 350, could I just drop and swap, i.e. intake manifold, wiring, pcm? Or would I be looking at needed a whole new setup.
Also, is a LS6 plug and play with a LS1 or am I looking at the same issue as the 350?
When you say 350 what do you mean?? 350 what???
an LS6 is 100% plug and play.
and just to clarify unless you are ferring to a Gen III/IV motor (ie and LS1-LS7) the head/intake and other parts will not bolt on on old SBC (350)
What did you blow up and what are you trying to put in its place? What model and year for car and engine.
A 350 is a Gen I Small Block Chevy from 1967 - 1995. 1996 - 2000 350's were vortec truck engines, and still had full interchangable parts.
From 1992 - 1997, LT1 350's were available in 'Vettes, Camaro - Firbirds and Caprice - Impala SS - Roadmaster.
Starting 1997, the LS1 came in 'Vettes, and in 1998 in F-body cars. It is 346 cubic inches, not 350 (no matter what car salesmen might say!)
This is the source of our confusion. Sorry to sounds like a smart ***, no flame intended here
Great post... I dont' know my SBC history well enough to post something like that.
Originally Posted by Fratsit
Slight correction.
The LT1 did not appear in the Camaro/FB until 1993. Biggest engine in the '92 Z28 was the a 350 TPI.
R/
Frat
R/
Frat
MagiC5 - Chevy made small blocks in 262, 265, 267, 283, 302, 305, 307, 327, 350 and 400 cubic inches, with bores ranging from 3.500 - 4.125 and strokes from 3.00 - 3.75
