Pennies in my Engine! VIDEO...
Old 01-08-2007, 03:26 PM
Regginator's Avatar
Default Pennies in my Engine! VIDEO...
I recently noticed a noise coming from my valvetrain that sounds like a penny being shaken in a glass bottle. The car doesnt have any problems running besides somtimes it takes two tries to startup or i gotta prime the fuel pump twice, which i believe is probably something in the fuel lines. This is the second motor in the car (or so i was told by the previous owner) so I have no idea how many miles are on it. It has 918 blue striped springs.
Click here to see Video
Hopefully someone knows what this is...
EDIT: The noise only comes from the passenger side of the engine
Old 01-08-2007, 03:51 PM
Kleeborp the Moderator™
MeentSS02's Avatar
If you haven't pulled the valve covers, do so and see what's going on. That would freak me the hell out, that's for sure.
Old 01-08-2007, 04:06 PM
RacerScott's Avatar
I wouldnt be running it anymore, thats for sure. Pull the valve cover.
LilSlo1's Avatar
Old 01-08-2007, 04:32 PM
Regginator's Avatar
What should i be looking for when i pull the valve cover? The other side doesnt make that noise so should i pull that cover off too and then compare the two?
Im going outside now to pull the cover, ill be back tonight with some pictures
Old 01-08-2007, 04:37 PM
TheLS1Kid's Avatar
check for a broken or loose valvespring.
Old 01-08-2007, 11:03 PM
Tech Resident
ChocoTaco369's Avatar
something is NOT kosher there. i agree with a broken valvespring. keep us posted.
Old 01-08-2007, 11:05 PM
TwistedSS's Avatar
Sounds like a bad valve spring IMHO
Old 01-09-2007, 08:53 AM
LilSlo1's Avatar
I remember someone posting this pic a few weeks ago. Anyways here's an example of a broken spring. (2nd spring from the left)
Also try looking for a broken rocker arm, or excessive valve lash (rocker arm slop between the valve stem and the rocker arm) which would indicate a bent push rod. Or even better if you still cannot find anything pull the rocker arms off, take out all of the push rods and roll them on a flat surface to see if any are bent. Hope it helps
Old 01-09-2007, 11:05 PM
1sick'98WS6's Avatar
Similar problem here... my pushrod was bent in three places and broken in half
Old 01-10-2007, 02:26 AM
Regginator's Avatar
Damn what kinda damage did that cause to everything else?
I havnt had time to take the valve covers off so no results yet...
Old 01-13-2007, 12:40 PM
loyolacub68's Avatar
so what happened?
Old 01-13-2007, 04:47 PM
N3V3RL8T's Avatar
if its not valve terrain I wold take off the accesory drive belt and check all pullys/ bearings.
Old 01-13-2007, 05:10 PM
9formula4's Avatar
sounds to me like you have a loose retainer or you lost a lock leaving the retainer loose and the lock inside the spring rattling.
Old 01-13-2007, 05:13 PM
8a8mfh's Avatar
Sounds like the a/c compressor clutch dragging. Does it do it with the a/c running? It should go away ith the a/c running. Or it sounds like a loose bearing in a tensioner pulley.
I would suspect a valvetrain problem to have more of a tapping especially a broken spring.
Old 01-31-2007, 02:11 AM
2000OnyxZ28's Avatar
Old 01-31-2007, 10:52 AM
CaliforniaBoy5's Avatar
interesting.
