Whining noise after hard turns
Old 01-08-2007, 08:52 PM
NoTicketsPlease's Avatar
Default Whining noise after hard turns
I was screwing off in a parking lot doing donuts and some pretty hard turns etc. Almost right away my car started to make a whining noise from the engine bay. I drove off and it was still present and would get louder when I turned then after a few miles it was gone. What is it?
Old 01-08-2007, 08:53 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
check your power steering fluid.
Old 01-08-2007, 08:57 PM
bmxer8699's Avatar
power steering fluid, or your power steering is failing.
mine starting doing that and then eventually i had to replace the power steering and pump.
Old 01-08-2007, 09:00 PM
ICEMAN 31's Avatar
yup this happened to me. It will go away and show up again if u turn hard, if you turn really hard the power steering will lock up. I took it to carmax with my warrenty and they had to change the rack and pinion setup. They found metal flakes in the power steering fluid. Thank you warrenty only cost me 50 bucks. I don't mean to scare you but chances are thats it. i was also doing donuts in the mall parking lot when i heard the first whine it was loud and then it went away. but the damage was done
Old 01-08-2007, 09:02 PM
bmxer8699's Avatar
Originally Posted by ICEMAN 31
yup this happened to me it will go away and show up again if u turn hard again, if you turn really hard the power steering will lock up. I took it to carmax with my warrenty and they had to change the rack and pinion setup. They found metal flakes in the power steering fluid. Thank you warrenty only cost me 50 bucks. I don't mean to scare you but chances are thats it. i was also doing donuts in the mall parking lot when i heard the first whine it was loud and then it went away. but the damage was done
i also had to change my power rack n pinion... all this happend because of one donut..
Old 01-08-2007, 09:10 PM
ICEMAN 31's Avatar
TA + Donuts =
Old 01-08-2007, 09:58 PM
damn.
Old 01-11-2007, 06:49 AM
Emfuser's Avatar
I have never done any donuts in this car and I really haven't even turned it that hard (since I'm trying to avoid major problems). Right now, my PS makes that whining sound on just about every turn, but it's only on turns, not constantly as I'm driving.
I opened the reservoir for the fluid, and I could see it in there, but I don't know what the proper level is and couldn't see if it was dark or not since I didn't have a flashlight handy.
Thoughts?
Old 01-11-2007, 07:04 PM
SScott236's Avatar
Mine just started doing too after a hard turn. Emfuser nice to see somebody else from columbia.
Quick Reply: Whining noise after hard turns
