Couple update pics of my Steel Gray SS and question about Wire Mod
Well I finally got around to getting back to work on my SS. I still have a lot more to do but got a few things done over the weekend.
Painted the back of my headlights
Installed my WS6 door panel with custom Steel Gray inserts. Just got to finish installing the WS6 dash now.
I installed my new rotors, pads, Camaro SS decals and painted the calipers.
Going this weekend to get the new tires put on these bad boys
Well I did the wiremod a year or so ago and was wondering what this one plug goes to?
Thanks
Thanks
Originally Posted by DEMONBIRD
I'm pretty sure the plug goes to the A/C low pressure sensor...
I love the color of you car and the rims but I'm not really feeling the shiny seat inserts...
btw your rotors are on backwards what type are they? if they are just o.e. style blacks that have been drilled they will be fine the way they are as the inner fins arent directional but if they are an aftermarket blank check the fins to make sure they are going the proper way for air to flow into them.
Originally Posted by GR33N GoblinM6
in reference to the calipers being painted... is that the same paint you used for the car? If so is it rated past 500*F? because if not.. that paint is going to come off.. and fast.
ls2 bait
You were right! I completely forgot about the tcs plug since it was removed when I had the engine bay painted. Thanks
I installed the rotors according to the box. I got them from the ws6 store and can be put on either way
https://ls1tech.com/forums/showpost....6&postcount=19
JerseyLS1TA
Heres a couple pictures of the Supra, I have a lot more in my sig
I have done a lot of work to that car too! I recently changed the rims, tires, brakes, turbo, custom exhaust, coilovers, complete sound system, custom leather, dash trim with polished bezels, all lights, HID's, some wiring, fuel pumps, motors at the machine shop getting rebuilt with CP pistons and Carrillo H beam rods. Only thing left is paint and its almost a new car lol
