Add coolant light is coming on but its full
Old 01-09-2007, 12:18 PM
ZRO
ZRO's Avatar
Default Add coolant light is coming on but its full
I was driving and went to park and my coolant light came on so I went and bought some antifreeze and added it. It went close to full so I figure I am good and start driving. The light comes on again maybe 2 minutes later so I pull over and check and this time fill it until its full. So start to drive again it came on again and stayed on. Car isnt overheating or anything. Is the sensor bad or what could it be ? Thanks
Old 01-09-2007, 12:22 PM
dirtyblackhoe's Avatar
jsut the sensor bad more than likely. mine does it all the time
Old 01-09-2007, 12:32 PM
MJK
MJK's Avatar
Yeah,the sensors commonly go out.It is an F-Body tradition.
As long as you are NOT actually loosing coolant,I wouldn't worry.
You can pull out the sensor and give it a good cleaning or replace with a new one.
Old 01-09-2007, 12:39 PM
MJK
MJK's Avatar
Just re-read your post and it does seem as if your losing coolant if I'm reading it right.You mention adding coolant twice I believe.
Check your hoses,coolant cap,...etc for any leaks.
Also check your oil for any coolant contamination and also your coolant for oil contamination.if you have any mixing of the two I might suspect a head gasket failure...but since the car isn't running bad or over heating...that hopefully isn't your problem.
Good luck.
Old 01-09-2007, 01:10 PM
ZRO
ZRO's Avatar
Good luck.
The first time I didnt fill it all the way up. Second time I did fill it all the way up didnt notice any leaks but didnt look to hard hopefully its just the sensor. Thanks
Old 01-09-2007, 02:21 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Welcome to the club.
Old 01-09-2007, 02:27 PM
SpaZMaN's Avatar
get that thing hot and check for leaks!(not too hot though, boiling coolant=OH SHI-)
Old 01-09-2007, 06:53 PM
ZRO
ZRO's Avatar
I see your from killeen too, are there any meets or hang outs for fbody around here ?
Old 01-09-2007, 06:56 PM
ZRO
ZRO's Avatar
Yea boiling coolant is never fun, it kinda pisses me off because i will drive for good 10-20 minutes and no light and think I am good to go and then bam think again ******* heres the light.
Old 01-09-2007, 06:57 PM
GregWS6&z28's Avatar
if cleaning the sensor doesnt work try a new radiator cap. happened to me. old cap wasnt holding the correct pressure.
Old 01-09-2007, 07:06 PM
ZRO
ZRO's Avatar
Thanks appreciate it will try that out.
Old 01-09-2007, 09:58 PM
PM sent.
