Very Bad Ticking
Old 01-09-2007, 12:23 PM
HoytVA's Avatar
Default Very Bad Ticking
allright after i installed my ms4 cam and double springs i noticed a bad ticking sound. though it was just piston slap, but im pretty sure its not. i can hear it all the time and it gets really loud at higher rpms. i checked the rocker arms and everything is ok. i dont know what it could be, maybe a lifter? any help is appreciated.
Old 01-09-2007, 12:33 PM
thehammer69's Avatar
Did you install longer pushrods when you did the cam?
Hammer
Old 01-09-2007, 12:35 PM
brad8266's Avatar
Hammer
You probably need longer pushrods. get a pushrod checker and use it to measure the distance you need.
Old 01-09-2007, 12:36 PM
HoytVA's Avatar
no i just installed chromemoly standard length pushrods
Old 01-09-2007, 12:38 PM
brad8266's Avatar
yeah you need to check the proper length.
Old 01-09-2007, 12:57 PM
There's your problem. Typically, the larger the cam, the smaller the base circle. The MS4 is pretty big so I imagine you lost much of your lifter preload. As mentioned by others, you need to measure for your lifter preload using a checking push rod. You should shoot for a .075" preload which will put you close to the center of travel on an OEM lifter. If you have to choose between going higher or lower, go higher but I'd max at about .100". My guess is that you need a minimum of a 7.425" push rod but optimally would be better with a 7.450" pushrod.
Hammer
Old 02-10-2007, 08:54 PM
1ORANGEWS6's Avatar
I have ticking noise as well but it just started about a week ago and I've had my cam for about a year now but it has only been running now for about 7 months.
