Sponsor Group Purchases - Strange 12 Bolt/Dana S60 Rearend Group Purchase
tbyrne
01-09-2007, 07:33 PM
The stock 10 bolt doesn't stand up to alot of horsepower. Especially when you bolt on sticky tires for the track. We've put together a group purchase to save you some money and to beat the Spring rush for these!
12 Bolt -
http://www.tbyrnemotorsports.com/ls1/strange12boltinfo.jpg
Gear ratios available are 3.42, 3.73, 3.90 and 4.10. The 3.90s will be noisy so Strange doesn't promote this one. This rearend now comes standard with the Super Strength posi. Each one is shipped ready to be installed. You will just need to swap the brakes from your current rear. Shipping is freight collect for this product so you will need to take care of that with the driver when he delivers.
GP prices -
PRG210-PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars) $2219.99
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin) $2219.99
R5206 Upgrade to aluminum support cover $114.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars.. $229.99
Dana S60 -
http://www.tbyrnemotorsports.com/ls1/danas60.jpg
Dana S60 features -
35 spline axles
HD Posi
Chrome Cover
3 or 4 channel ABS
You will need to send your brake backing plates in just before the rear is built so they can be built into the rear. We can sell a new set to you separate. The stock driveshaft will need to be shortened by 1.625".
The following gear ratios are available - 3.54, 3.73, 4.10, 4.30, 4.56, 4.88, 5.87.
The weight difference between Dana 60 and 12 bolt is 20-25 lbs, the Dana is heavier. Dana rear is fully assembled with posi weights around 215 lbs and 12 bolt is around 189 lbs (weight with brakes). The weight difference between 12 bolt and 9" is about 12-15 lbs the 12 bolt being lighter.
Ring gear sizes:
12 bolts ring gear only 8.875 OD
9 ring gear is is 9" OD
Dana has ring gear of 9.75 OD which is alot stronger than 12 bolt & 9".
The standard Dana gear (not Pro) can withstand close to 1200 RWHP.
The True-Track is posi is standard along with Power-Lock. These are good for about 600rwhp. The Dana's posi is alot stronger than a 12 bolt and the 9". This is because the Dana Posi's are 35 spline, 12 bolt is 33 spline and the 9" is a 33 spline.
GP prices -
PRSF05 Strange Dana S60 $2049.99
Driveshafts for Dana S60
U1699 Strange U1699 driveshaft 3"x.083" DOM chrome moly driveshaft with H.D. U-joints $209.99
U1700 Strange U1700 driveshaft 3"x.083" Seamless chrome moly driveshaft with High Imp. U-Joints $329.99
U1702 Strange U1702driveshaft 3"x.083" Seamless DOM chrome moly driveshaft with H.D. U-joints $289.99
5 or more orders are required by Tuesday, January 23rd for this to go through. We will start ordering these when we have 5 orders in so it will be good to order early! This GP covers all rears that Strange produces so let us know if you need a rearend for a vehicle that isn't listed here.
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763.
Have a good day!
SuperSport4life
01-10-2007, 10:10 AM
Very intrested in the strange 12 bolt
Could you pm me pricing for a 01 Camaro SS
4.10 gears
trutrac
3 channel abs (no traction control)
Thanks in advance!
MoesSS
01-10-2007, 12:54 PM
I'm in. I am just waiting for my taxes to get back to me.
98 SS
w/abs, no trac con
4:10's
W8N2SQZ
01-10-2007, 11:43 PM
I need a price for a 9 inch.
2000 SS
3.50 gear
trutrac
iron center section
4 channel ABS
I can send in my brake backing plates.
Thanks,
Glenn
SILVER SS 00
01-11-2007, 06:55 AM
same here looking for a 12-bolt for ls1 00 ss,let me know on a price.4.11s,performance cover,33 spline,longer studs,with traction control & abs.
Jpr5690
01-11-2007, 09:07 AM
Im In For A Dana 60 .. Ill Be Placing My Order Mid Next Week!
This Is A Really Good Deal Its About $1000 Cheeper Than I Could Get It Built For Locally...wow!
DROPTOPLS1
01-11-2007, 10:03 AM
I need a price for dana 60 trutrac,373,w abs no traction control,my backing plates shipped to 14150.
NumberOneSled
01-11-2007, 11:22 AM
Are there any options on the cover for the Dana S60?
SILVER SS 00
01-11-2007, 06:28 PM
still waiting on price quote
tbyrne
01-11-2007, 08:22 PM
Everyone that requested prices.... they are all listed in the first post.
These rears are shipped freight collect from Strange so we aren't able to get a firm quote. Rates change with the price of fuel so it wouldn't be the same when they ship anyway. A rough estimate is usually in the $125. - $250. range. The trucking co would call a few days ahead to set up the delivery and prove the shipping amount due.
SILVER SS 00
01-12-2007, 11:14 AM
i did e-mail you two days ago,still have not gotten a price quote
tbyrne
01-12-2007, 11:22 AM
We don't have any outstanding e-mails as of this morning. We might not have received yours or you didn't receive our reply. Spam programs sometimes pick up good e-mail. The Spam box here is usually scanned through and cleaned out daily.
SILVER SS 00
01-12-2007, 11:32 AM
not bad thought i did,but i just sent it sorry for that
tbyrne
01-12-2007, 01:30 PM
No problem at all :)
A few people have asked about the driveshafts for the S60. Info for them is -
The U1699 Seamless Chromeoly Driveshaft with Strange Heavy Duty Yoke (primarily street use)
U 1702 Seamless Chromeoly Driveshaft with Forged Strange Yoke (Street/Strip Use)
U 1700 Seamless Chromeoly Driveshaft with Strange Ultra Solid U-joints (Serious Drage Racing)
NumberOneSled
01-13-2007, 10:19 AM
Just wondering if the Chrome cover is the only option? Thanks
BryanJohnson
01-14-2007, 09:02 PM
how much for a bare dana 60 housing? thats with me sending you my brake backing plates to be installed as well
LT1MAN
01-16-2007, 07:48 AM
whats the difference between the strange 12 bolt and the dana s60?
tbyrne
01-16-2007, 01:45 PM
The chrome cover is offered for the 12 bolt but not the S60.
The S60 can be ordered bare or complete with backing plates installed.
They will not install backing plates on a bare housing. The bare housing is
part number H1100FB, GP price would be $879.99. Our regular retail is $939.99.
I had a comparison between the two rears. I'll see if I can locate that.
LT1MAN
01-17-2007, 06:48 AM
thanks
NumberOneSled
01-17-2007, 11:59 AM
Can the Rear be shipped to a house? I plan on placing my order in the next couple of days. Thanks
firehawk67
01-17-2007, 02:19 PM
I will be ordering mine on friday (posted on camaroz28.com as 95firehawk). I would also like to know if the crate have to be returned (core charge?)
Jpr5690
01-17-2007, 03:55 PM
Are Their Any Driveablity/ Reliablity Issues In Choosing The 1700 Driveshaft Over The 1702 ?
I Want The Strongest But I Do Street Drive The Car..
Also Has Anyone Considered A Detroit Locker In The S-60
Jpr5690
01-17-2007, 08:43 PM
also does shipping to a business allow for less of a fregit charge (over shipping to a residential address)
tbyrne
01-18-2007, 12:55 PM
No problem shipping these to a residence. They can also goto a business but you'll just need to add that to your card as an alternate shipping location. Your credit card company can usually do that in a few miniutes. They put the info in the Notes field but it doesn't change anything else. Freight can be a little cheaper if it goes to a business.
The crate doesn't have to be returned. It makes good fire wood :)
There shouldn't be any driveablity issues with any of those shafts.
firehawk67
01-18-2007, 02:57 PM
Awesome. You will be hearing from me tomorrow morning. Woohoo! No more 10 bolt headaches!
Fbody98
01-18-2007, 10:18 PM
i wish tax returns were in otherwise id jump on this!!!!
junior28570
01-19-2007, 02:43 PM
If the S60 will work with a pro-kit dropped T/A, I'm in.
Email on sent on the specifics.
firehawk67
01-19-2007, 03:09 PM
Ordered mine as of 8 a.m. this morning. That made 4 for sure. Just need one more.
junior28570
01-19-2007, 05:05 PM
If I could get a return call or a return email, answering my questions .. I'd be able to place my order :(
Maybe someone here will know the answers to my questions;
S60:
Any clearance issue with a pro-kit?
Any problems with factory compatable adjustable TA or bolt-on relocation brackets?
Jpr5690
01-19-2007, 07:47 PM
i dont think the 10 bolt relocation brackets will fit.. because when i ordered mine (brackets) they said that they wont fit anything except the 10 bolt ...
Jpr5690
o yea, ordering my s-60 tommrow
tbyrne
01-20-2007, 10:41 AM
S60:
I believe I answered an e-mail like this a couple of days ago. I believe the subject was something about asking advise. I'll locate that reply and resend it.
junior28570
01-20-2007, 11:33 AM
It just showed up ... Thanks for the info!! I'll leave the details of my purchase in a reply to your email.
Thanks again!
I'll be giving y'all a call Monday for sure!
Jpr5690
01-20-2007, 12:30 PM
well shit ur closed!
Jpr5690
01-20-2007, 12:34 PM
ok guess ill order on monday...
tbyrne
01-22-2007, 11:11 AM
5 in now. This GP is a go!
firehawk67
01-22-2007, 11:32 AM
Yes!!!!
NumberOneSled
01-22-2007, 04:14 PM
Ordered mine today!
Jpr5690
01-22-2007, 05:25 PM
Yeay!!!!
Jpr5690
Just Out Of Curosity What Drive Shaft Did You All Order?
shocker45
01-22-2007, 06:17 PM
is it to late to place an order? and if not how fast to i need to do this.
also, how do i go about shipping this over the border, without getting hit with huge fee's. or what if i ship it to my friend just south of me lives in north dakota. and i drive down and pick it up?
im not sure what i need, so could someone help me out
ive heard the Strange 12 bolts are good,
my car is my sig,
i have traction control but hate the damn thing so its never on, so i dont know if i need that sensor deal.
im getting good tires this year and want to prevent my rearend from popping. so someone help me out.
Jpr5690
01-22-2007, 07:48 PM
gp ends tuesday.. 1 bolt is good but why when the s-60 is so close in price? you dont have to get traction controll (it can be just unplugged) this would also save you a little money but if you want to keep abs then you need to get a rear with of 4 channel abs (more money)...
Jpr5690
01-22-2007, 07:49 PM
anayways.. now that this is a go can you all e-mail me a recipt..
my name is john regan my e-mail address is jpr5690@aol.com
thanks!
shocker45
01-22-2007, 08:29 PM
so i have to order by tommorow? that is kinda pushing it, i wish i saw this post a long time ago. i ahve no idea how to get this thing over the border.
NumberOneSled
01-22-2007, 08:34 PM
I went with the Street/Strip Chrome Moly. Part # U1702
Jpr5690
01-22-2007, 08:57 PM
yea i did the 1702 also i was thinking to do the 1700 but i was understanding they have viberation issues in a street car?
junior28570
01-23-2007, 02:57 AM
I went with the 1699 .. You haven't heard of any vibration issues with that one, have you?
Jpr5690
01-23-2007, 07:35 AM
havent heard anything (didnt ask)
NHRAFORMULA00
01-25-2007, 10:43 PM
Does Strange offer a spool for the 12 bolt,and if yes what ratios.Looking for 4.10 or 4.30
Stangkilr
01-26-2007, 12:03 AM
Price shipped on a Moser 12 bolt and Dana, 4 channel, 4.10's.
tbyrne
01-26-2007, 08:06 AM
Strange does offer a spool for their 12 bolt. Gear ratios available are 3.42, 3.73, 3.90 and 4.10.
This GP wrapped up Tuesday. We are able to extend the GP pricing through next Friday (February 2nd) so there is still time to place your orders!
shocker45
01-26-2007, 10:22 AM
can you give me a total on a rearend, i live in canada so this is a huge pain.
moser 12 bolt, 4 ch abs, 33spline, eaton posi. 4.10's
one of them shipped to grand forks area, zip code 58201.
or if its not much more, to Winnipeg, MB, R3B 3P3, this is a business address.
and also do you know the rules of shipping accross the border?
tbyrne
01-27-2007, 11:47 AM
We carry the Strange rearends but not the Moser. Just want to make sure that's the one you want :) The rears are shipped freight collect so we aren't able to get any firm shipping quotes.
Stangkilr
01-29-2007, 12:37 AM
Sent you guys an e-mail under "stangkilr99@hotmail.com"
shocker45
01-29-2007, 12:39 AM
well how much would the moser 12 bolt, 4 ch abs, 33 spline axels w eaton posi run me? and would it be a direct bolt in application?
just trying to figure out if its worth it to do this group order thing
NumberOneSled
02-03-2007, 04:36 PM
Any idea when the rears will start to ship?
tbyrne
02-04-2007, 09:50 AM
I expect them to start shipping the end of this month.
NumberOneSled
02-04-2007, 02:17 PM
Why does it take 6 weeks to get a rear from Strange? Not trying to be a pain, just curious.
shocker45
02-04-2007, 04:19 PM
k, how much is it going to cost me to get a 12 bolt strange, 4.10 gears, eaton posi, 33 splines, 4 ch abs. and traction control,
shipped to grand forks, 58201?
tbyrne
02-05-2007, 08:26 AM
I'm not exactly sure why it takes so long. I know that they build alot of stuff up there. Most of our current orders have been shipping in about 4 weeks.
shocker45:
GP prices -
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will either need to send in your backing plates & reluctor rings or purchase them seperately. $229.99
OPRG13 Reluctor Ring Set $69.99
The GP prices were supposed to end on Friday but we will honor it for orders placed through today.
1320 killer
02-05-2007, 11:05 AM
Is this still available? heres what I need:
373's
full spool
33 spline
no other options. what is the price?
Jpr5690
02-06-2007, 11:21 AM
THATS NOT COOL, I PAID $315 FOR MY PLATES AND RINGS WHEN I ORDERED THEM A WEEK AGO... I EVEN CALLED AND QUESTIONED IT BUT NOW THEIR $229 :cry: ???
shocker45:
GP prices -
Jpr5690
02-06-2007, 11:24 AM
I Think I Was Priced....
Plates $230
Rings $70
Shipping $15
Jpr5690
02-08-2007, 06:27 PM
tbyrne
02-09-2007, 07:55 AM
What do you need to know?
Jpr5690
02-09-2007, 07:49 PM
In Post #62 I Asked If Was I Charged Properly; Because In Post #60 You Make It Sound Like Its Only $230 For Backing Plates And Rings But As I Stated Above, I Was Charged $315 And Am Just Wondering If This Is Correct?
Jpr5690
02-11-2007, 11:24 AM
any reply?
tbyrne
02-11-2007, 01:17 PM
Yes, you replied after we closed on Friday. But I'm taking care of some things today and can give you a reply. Pricing listed in post 60 -
The reluctor rings are located on your axles so those used to have to be sent in with the backing plates if the car had traction control But, the rings are now available seperate so that saves the trouble of pulling the axles and have downtime. The backing plates are $229.99 + $69.99 for the rings and then shipping to get them to Strange.
Hope this helps!
QuickdomesticRacer
02-12-2007, 06:58 PM
Are these prices still current. Are the Dana 60's still available cheaper than the 12 bolts at 20XX.XX??
Thanks.
dafaic
02-14-2007, 08:26 AM
^double that?
SSinNC
02-19-2007, 05:59 PM
^triple that!
tbyrne
02-19-2007, 07:22 PM
You three guys.... and anyone else... order by Friday (2/23) and YOUR IN! :)
Tom
BIG BAD BLACKSS
02-20-2007, 03:32 AM
Damn damn damn, im gonna have to decide between 9" and S60 faster then i expectedi guess. S60 gonna be abloe to take 7-900RWHP coming of a trans brake dead hooking?
Ive heard due to the bearing placement (no extra bearing on the far end of the pinion gear) that after a couple hard launches they may develop a gear whine? Also, you said the stock posi units are only good up to about 600rwhp, is a detroit locker an option? Anything else that will hold up to the power im looking to put down?
SSinNC
02-20-2007, 04:34 PM
I will be calling you guys tomorrow. Thanks for letting me still get in on this group purchase.
tbyrne
02-21-2007, 11:29 AM
Some info/part numbers have changed since this post went up. This is the current listing -
PRSF05 Strange Dana S60 (will need to purchase a new driveshaft or send yours in to be balanced with the new rearend) $2049.99
Options
R5206 Upgrade to aluminum support cover (not available for the Dana S60) $114.99
True-Track Upgrade to True-Track Posi $79.99
Detroit Upgrade to Detroit Locker Posi $79.99
U1702 Strange U1702driveshaft 3"x.083" Seamless DOM chrome moly driveshaft with H.D. U-joints $299.99
Someone called or e-mailed to ask about the GP this morning. The person he talked to wasn't aware of this being opened up until Friday. Everyone here knows now.
NumberOneSled
02-21-2007, 03:28 PM
Difference between true-track and true-track posi? HP rating?
SSinNC
02-21-2007, 03:51 PM
Thanks for the great deal Tbyrne. I ordered my s60 today. Hope fully I will receive it in the next 4 to 6 weeks. :)
tbyrne
02-23-2007, 10:03 AM
I think you might mean the difference between the Track Loc and True Track? The True Track is the next step up. It's going to be a little more durable but will remain streetable.
Last call!
NumberOneSled
02-23-2007, 10:41 AM
"True-Track Upgrade to True-Track Posi $79.99" I ordered my S60 last month and when I saw this posted a few days ago I called to upgrade. Did I just upgrade to the true-track or is it posi?
Jpr5690
02-26-2007, 10:11 PM
hey great news got mine installed today and it sounds like shit!!!!
right out of the shop parking lot all i heard was whineing and grinding along with some clunking
this thing is definately gonna need some work so i guess im going to call strange tommrow morning to see what their going to do
i am pretty god dam pissed off!!!! i just spent $3000 with these guys and i have a broken rear end !!!!!!
shocker45
02-26-2007, 10:21 PM
which kind did you buy?
NumberOneSled
02-27-2007, 12:29 AM
Mines coming in tomorrow, I hope I don't have any problems. Good luck
stange567
02-27-2007, 08:01 AM
im in just 300 $short dana 60 detroit locker
Jpr5690
02-27-2007, 09:35 AM
yea mines all fucked, waiting on a call back from strange to see what they are gonna do to fix this issue
Jpr5690
02-27-2007, 01:16 PM
ANY COMMENTS TBYRNE?
btw I ORDERED THE S60, TRU TRACK WITH THE STRANGE DRIVESHAFT
junior28570
02-28-2007, 02:47 AM
Keep us posted John .. that shit needs to get worked out ASAP!
Let us know who steps up and who don't.
Jpr5690
02-28-2007, 08:16 AM
waiting on a call back from strange today they said they were going to have it inspected locally....
from my reading this isnt the first, second or 3rd case of this....
http://www.ls1tech.com/forums/showthread.php?t=666649
tbyrne
02-28-2007, 09:08 AM
Just read your post and am checking into this now.
Jpr5690
02-28-2007, 09:36 PM
Ok Thanks.. Next Level Performance Is Already Scheduled To Rebuild The Unit Next Week.. In This Case It Seems So Far Strange Is Stepping Up To The Plate And Owning Up To The Rebuild Without Much Confrontation
Thanks For Your Intrest In My Situaion Im Happy To See That This Should Be Resolved Easily
Jpr5690
02-28-2007, 09:38 PM
Also I Will Say So Far Strange Has Been Pretty Freindly And Help Full
They Admitted Their Worng In The Situation And Allowed Me To Pick A "mutally Agreed Upon Shop" To Rebuild The Unit At No Addional Cost To Me
Also Tis Isue Has Been Handled In 2 Days And I Am Scheduled For My Rebuild Next Week
At The Pace Of Things I Would Say Im Pretty Happy With The Responce Thus Far...
I Will Keep This Issue Updated & Post A Conclusion In About 10 Days
Thanks!
-john
SSinNC
03-05-2007, 04:06 PM
I hope strange does a better job recognizing their faults and starts to build the s60 to better specs, because I ordered one about a week ago. You guys got me all worried.
Jpr5690
03-06-2007, 10:16 PM
well mines at NLP as we speak getting tore down, i know theres a problem with my pinion seal leaking on top of everything else i mentioned but the jury is out as im waiting to see how the unit works when set up properly before casting an opnion
BIG BAD BLACKSS
03-19-2007, 03:30 AM
How did it all work out? What was wrong with it from the factory?
Jpr5690
03-19-2007, 11:05 AM
Picking Ym Car Up On Friday So Ill Update Then...
Jpr5690
03-26-2007, 08:38 PM
Ok Got It Back Together And Everything Is Great Now.. Strage Fixed Everything With The Help Of Next Level Performance And Now Im Totally Happy.. Thanks Guys!
edwardzracing
03-27-2007, 12:13 PM
Don't mean to rob the thread... just curious if there is still a deal available on these?? Just thought I'd check. Thanks!
junior28570
03-27-2007, 01:03 PM
Glad to hear it John!
Bravo!! ... to Strange and Tbyrne for getting this worked out!
Jpr5690
03-27-2007, 01:54 PM
FUCK YEA! CANT WAIT UNTIL MY 250 MILE BREAK IN IS OVER FOR SOME FUN DRIVIN
btw DRIVE LINE SOLUTIONS IS OFFERING A GP ON STRANGE DANA 60'S RIGHT NOW...ALSO THEY ARE GOOD PEOPLE TO DEAL WITH
A_W_O_L
05-02-2007, 07:25 PM
Ive left 2 messages now and still no response...
I guess they're kinda busy.
Drake
05-03-2007, 02:26 PM
Ditto... can't wait to hear from Scott though. Anyone have the details on their GP?
quickta
05-10-2007, 03:13 PM
THE G.P. PRICE FOR PRSF05 Strange Dana S60 $2049.99 , COULD YOU PM ME A PRICE FOR THE SAME BUT WITH A SPOOL
Camaro-Sutra
05-11-2007, 05:34 PM
Ok so where are details on current GP for a 12 bolt or dana S60? This still going on? I need a new rear for the new power i plan to make.
William
Drake
05-12-2007, 01:48 PM
I just ordered an S60 and 1K HP driveshaft from Scott at Driveline. He took the time to talk with me and help me spec the products for my needs. One of the other sponsors who is running a special couldn't even tell me anything ABOUT the special (IE, what the price included). It was obvious Scott knew his stuff, so I decided to pay a little more to feel more secure in the product.
Let's hope all goes well. :drive:
tbyrne
05-15-2007, 10:00 AM
This GP ended in... February :)
We do have the Strange 12 bolts and Dana S60 rears on sale through. The discount is $200.00 off of the prices that are listed on our website.
Camaro Rick
06-10-2007, 01:21 PM
How long is that sale going on? How are we eligable for the discount? Also, How much is shipping (perhaps to southern New Hampshire)? I understand you guys typically send these C.O.D. shipping. Thanks!
