Fueling & Injection - Stock Fuel Pressure Droops at WOT
View Full Version : Stock Fuel Pressure Droops at WOT
Gary Z
01-09-2007, 09:38 PM
I just finished installing a precision pressure sensor on my fuel rail and I thought some of you might be interested in seeing how the stock pump and regulator perform. I believe that my fuel system is in like-new condition. The sensor is a Measurement Specialties model MSP-600-100 and the data was recorded through an HPTuners EIO interface.
Old Geezer
01-10-2007, 09:38 AM
Is the green line the averaging that you drew in?
Where did you purchase the sensor?
Expensive?
Doesn't look like it took long for the system to lose it's "steam"!! :cry:
Gary Z
01-10-2007, 10:16 AM
The green line is a linear trendline drawn by Excel. The sensor was about $80 from Digi-Key. My fuel pressure is 59.2 psi at idle.
-Gary
MeentSS02
01-10-2007, 11:24 AM
That looks nearly identical to what I see for a pressure drop in my car using an Autometer gauge through the HPT EIO. I think it might be somewhat inherent to a returnless fuel system (well, not being regulated at the rails is really the issue IMO).
Gary Z
01-10-2007, 01:42 PM
That looks nearly identical to what I see for a pressure drop in my car using an Autometer gauge through the HPT EIO. As I mentioned, I was reasonably certain that my fuel system is behaving normally, but it is good to have confirmation. Thanks.
Gary Z
01-10-2007, 01:56 PM
An added note: At first glance, fuel rail pressure regulation of the stock system seems to be very poor, but since flow is proportional to the square root of pressure, flow will only vary about nine percent if pressure stays within the range 60 to 50 psi.
BIG_MIKE2005
01-10-2007, 02:00 PM
So then as long as you never see your gauge dip below 50 SPI everything is fine?? I"m still learning about these fuel systems, so pardon my stupid question.
Gary Z
01-10-2007, 02:47 PM
So then as long as you never see your gauge dip below 50 PSI everything is fine? I wouldn't say everything - fuel supply system is probably ok. :) On the other hand, I am not satisfied with the original pump and plan to install a Racetronix system.
BIG_MIKE2005
01-10-2007, 03:00 PM
ok, so if the pump, injectors & rails are all swapped out, should the pressure drop disappear??
Gary Z
01-10-2007, 04:04 PM
As MeentSS02 says above, you probably won’t eliminate the pressure sag unless you also move the regulator to the rails and install a full length return line.
BIG_MIKE2005
01-10-2007, 04:17 PM
ok, thats what I was thinking since the system would still function the same only flow better.
MeentSS02
01-10-2007, 04:51 PM
Yep...these are definitely the same thoughts going through my head...my idle rail pressure is 58 psi, and drops to about 52-ish psi by the end of the RPM range going WOT. I'll eventually swap out the stock pump for a Racetronix piece, and I'll think about running a full return line setup.
The only problem this poses is with the injector duty cycle...if the pressure drops, the injectors have to stay open longer to compensate. That's why I'm currently running 30-lb injectors (rated at 43.5 psi, so they are more like 34.6 or so lb/hr) on my stock internal car.
RedHardSupra
01-10-2007, 07:49 PM
yup, i've seen the same thing, even on upgraded hardware.
from what i've seen, it's not only MAP dependent, but also RPM dependent. once you combine them together, you end up with a very nicely direct relationship between fuel pressure drop and airflow.
http://redhardsupra.blogspot.com/2006/12/under-fuel-pressure.html
Gary, what kind of resolution do you get on the fp sensor?
MeentSS02
01-10-2007, 09:56 PM
Marcin,
I still don't fully understand why the IFR table as it comes set in the PCM has values that go up with increasing MAP, while we end up seeing the opposite...was this done for a reason?
Gary Z
01-10-2007, 11:16 PM
Gary, what kind of resolution do you get on the fp sensor?Accuracy and resolution are both better than one percent. Resolution is determined by the 10-bit analog-to-digital converters in the HPTuners interface. The accuracy of the sensor is supposed to be 0.25% of full scale - 100 psi. Accuracy is much better than necessary because of the relatively large puslations caused by injector activity.
RedHardSupra
01-11-2007, 07:57 PM
Marcin,
the injectors.xls that got so popular on this forum is not my work, i found it on the internet without credit. it had it (wrongly!) marked the pressure as MAP, not MANVAC which it should be--that's why you're probably 'looking at it the wrong way'
new version is pretty much done, just needs some cleanup, i fixed the labeling and it can calculate IFR from either estimated FP or the actual different FP vs MANVAC table if you can scan for it using a FP sender.
MeentSS02
01-11-2007, 09:04 PM
Ohhhhhhhhhhh...that makes a little more sense. Nevermind me...
