ls1 harness on ls2 engine , engine not starting !!
yes, the wires from the PCM need to be reversed if you are not using a harness for the LS1 > LS2 swap (the harness should already has the pins swapped)
Just switch the outside wires, pin 1 and 3 and leave the middle alone. Of course if you havent already done that!
Originally Posted by 02 BLK WS6
Reluctor wheel on the crank is for an LS1 right?????
i swaped the cam sensor wiers 1 with 3 nothing happened:S
thanx alot guys....finally we fire it up today....
the problem was form the harnesses it self....by the way it's 240sx with an LS2 and G5x3 MTI heads...T-56..with 4.10...and about 2500 lb (full wt.)
will post some pics for the conversion soon..
thanx again guys...
thanx again guys...
