Crossmember bolt hole locations
Search is down so........... maybe a retarded question but I am curious about transmission crossmembers. Does the type of crossmember you use depend on 1) the motor (LSx or LTx) or 2) the actual location of the bolt holes? Let me explain, does the motor change the dimension (actual location of the driveline components) OR are the bolt holes in different locations for different models of the F body? Reason I ask is I am piecing together an LSx project in a factory LTx car.
