LS6 Heads from Patriot Performance
Anyone running the Patriot Performance LS6 stage 3 heads....if so what do you think of them and how much did you pay for them
I have the stage II ls6's on mine. 347, ms4 m6 and 12 bolt on slicks. With the ls6 and ported tb it put down 441/405. Just switched to the 90/90 and haven't had a chance to do anymore pulls to see where I'm at now.
How do you like the MS4
Is that with a LS6 intake?
Originally Posted by 2K1WS6TA
so your car laid down 441 with LS6 heads and the MS4 with ported TB?
I got 2001 ws6. PP ls6 st II heads 2.02/1.57 59cc. comp cam 231/237 .589/.595 112 kooks lt, stock intake (LS6) ported stock TB, true duals dumped. stock 3.42 . made 418rwhp 389rwtq. on stock clutch.
fuerzaws6
Originally Posted by cowboysfan
dynojet or mustang?
fuerzaws6
fuerzaws6
It was on my dyno which is dynojet. And it is sae numbers not std. I started out at 424/395 through a hooker catback. Put a cutout on it and a ported tb and went from 424/395 to 437/402. My throttle cable wasn't opening up all the tb all the way so I unclip it from the bracket and slid it behind the bracket and got 441/405. I could have picked up another 5 or with some tweaking on the tune it was a little fat after opening the exhaust and adding the tb. Hoping for 460/420 with tuning and the fast 90/90.
What cc are the chambers , what thickness headgasket did you use .
any problems with the Fast 90/90 ?
fuerzaws6
had it on for about 2 weeks now, and haven't had any probs. Gonna tune and get some dyno numbers then pull it off to have it ported and test again to see how much it really gains. I'll try and get a graph up sometime this week when I get back to my shop.
Originally Posted by PREDATOR-Z
The stage 3 LS6 as you call them are "LS6 STYLE" not true LS6. They are in fact 6.0 heads.
Stage 3 is for 4.00 bore +
Actually, unless they are a 59, 68, or 72cc heads, they will be a 243 casting.
