Howling!
Howling!
I have been able to hear a wierd howl coming from the front tires. I can hear it best at about 60 mph. I have aftermarket rims and Fuzion zr 1 tires that have about 50% tread left. Could this be a wheel bearing getting bad or is it the tires themselves? Is there anyway to check if there is bearing going out. Also the car does pull very slightly to the left if that helps.
if the bering is out you should be able to wiggle the wheel when the suspension is unloaded and the tire is off the ground. i think your just hearing road howl from a wide tire. enjoy it
