General LSX Automobile Discussion Non-technical LSX related topics.
I'm Retarded!!
Old 01-12-2007, 02:50 AM
razorclaw99's Avatar
Default I'm Retarded!!
i bought a short throw and in order to put it in, you need to take off the console. well you need to lift the ebrake completely up so its actually vertical to slide the console off.. In doing so i snapped the e-brake cable lol.. I didnt even do it hard..
So now i cant even idle or the car will roll..How hard is this to fix? Is all i need is a new wire?? i have no idea how to fix this problem
Old 01-12-2007, 03:37 AM
SpaZMaN's Avatar
sounds like all you need is a new cable!
Old 01-12-2007, 04:10 AM
how much do those go for?
also can i just rewire?
Old 01-12-2007, 05:35 AM
Dex
Dex's Avatar
I never took off my console to put on my short stick. I pulled off the boot and removed the shifter pretty simple. You must have never used the e-brake before. You can wire it back together is you want not hard or replace the cable that broke.
Old 01-12-2007, 12:00 PM
JerseyLS1TA's Avatar
Yeah my friend did it on his Camaro and all he had to do was take off the shifter and boot. How high did you pull up the e-brake.
Old 01-12-2007, 12:09 PM
cwaldt's Avatar
I've taken the consoles out of Camaro plenty of times and never had a problem. To fix it I'd just go to a junk yard and get the parts you need.
Old 01-12-2007, 12:11 PM
lastcall190's Avatar
It's not that easy on all cars. On mine I had to take off the sound deadening rubber boot where the bolts are nearly on the SIDE of the tranny tunnel. On my old LT1 something strang would happen, the e-brake would sometimes hardly go up at all, something that felt like self adjusting. If I tried to pull on it it would've probably snapped. Good luck on the fix, which shifter did you get.
-J
