what is stock fuel psi
Old 01-12-2007, 12:19 PM
SoCalZ28's Avatar
Default what is stock fuel psi
What is the fuel psi supposta be at for our ls1's?
Old 01-12-2007, 12:21 PM
Nasty N8's Avatar
58PSI
Nate
Old 01-12-2007, 01:00 PM
SoCalZ28's Avatar
is that at idle?
Old 01-12-2007, 03:48 PM
andereck's Avatar
Everywhere. The regulator is in the tank and not referenced to vacuum.
Old 01-12-2007, 04:02 PM
cabech984's Avatar
GM Service Information says it should be 55-60 psi at idle, Mine had 60 @ idle. the gauge stayed at a constant number in my case.
Old 01-13-2007, 11:58 AM
DrkPhx's Avatar
Thank you. This should be a sticky in this forum because it's asked so frequently.
Old 01-13-2007, 12:17 PM
rez0469's Avatar
mine also stayed at a constant 60 at idle
Old 01-13-2007, 05:28 PM
dalez28's Avatar
mine was 58-59 psi consistantly when I was stock.
