New tb installed....now high idle
Old 01-12-2007, 03:47 PM
bow125106's Avatar
Default New tb installed....now high idle
just put a ported tb on the car and now i have a high idle,,,,,goes from 1000 to 1500...........i noticed that when i looked at the tb i can see past the butterfly.........like its not completely sealed..........What do i need to do??
Old 01-12-2007, 04:35 PM
JerseyLS1TA's Avatar
Did you port it yourself? Sounds like you may have taken to much off
Old 01-12-2007, 04:56 PM
bow125106's Avatar
Default .
no, bought it from a member
Old 01-12-2007, 05:32 PM
Da Swami's Avatar
I would try adjusting the idle screw on the passenger side of the throttle body.
Old 01-12-2007, 05:42 PM
hpjunky98's Avatar
Same thing happened to me. The TB is ported incorrectly, as it lets more air into the intake at idol, making it higher
Old 01-13-2007, 09:12 AM
KENS_SS_4's Avatar
What was the reason for the new throttle body?
Old 01-13-2007, 09:26 AM
Morbid's Avatar
Are you sure the arm on the TB shaft is the same size as yours? 98-99 are smaller than 00-02. If you have a 98-99 car and bought an assembled TB for an 00-02, then your TB is being held open by the throttle cable. It's easy to swap the TB shafts around, you just need a couple torx bits.
If it's the correct size, then check the idle screw where the TB arm rests at the closed position. It's possible it may not have an idle screw as well.
Before putting the TB on, were you able to see large gaps around the TB blade itself when in the closed position? More of a gap = more air passing by the blade when closed.
Old 01-13-2007, 09:38 AM
bow125106's Avatar
Default tb
its the right tb for my car ,,01 z28,,,yea i could see a gap but from what im reading,,just about all of them have gaps.......it does have that adj. screw, will that help me out,,,thought these cars could not be adjusted manually
Old 01-13-2007, 09:42 AM
JL8Jeff's Avatar
Try adjusting that stop screw. Sounds like it's holding the plate open too far. I put on a ported TB last weekend and it works great. My car idles back down to 600 rpm's like normal. Throttle response is much better with the ported TB.
Old 01-13-2007, 10:55 AM
Brews02SS's Avatar
the same thing happened to me also, check the hole that is in the blade. the hole was to large in the one I bought so my car idled high until I switched the blade out for my stock one. then it idled perfect.
Old 01-13-2007, 01:52 PM
staringback05's Avatar
ahhhh we have a smart member....to the man with the problem, this is probably going to be your cause....as stated 98-99 flanges are different sizes then the other years, therefore the throttle cable doesnt stretch as far...and keeps the blade open.....switch out the flange
Old 01-13-2007, 02:04 PM
bow125106's Avatar
Default tb
pretty sure the tb came from a 00 ta...i have a 01 z
Old 01-13-2007, 02:42 PM
the 00 also might be different i know my 01 and my 99 were totally different
Old 01-13-2007, 03:17 PM
2QUIK4U's Avatar
The same thing happened on my friends car when he put on a BBK throttle body. I adjusted the screw for the stop and the idle went down to normal. If that doesnt work it might have been ported to much.
