evac system
Old 01-12-2007, 05:58 PM
Rusted40's Avatar
Default evac system
I posted this in advanced . no replies
this section gets a little more traffic
he's installing it tomorrow.
I will post results if any of you guys give a crap
Originally Posted by Rusted40
well not really but...
a friend is hooking one up to his blown BBC camaro with a WOT switch
maybe an aeromotive fuel pump controller later?
it sprays the windshield through the breathers under full boost
he is hoping this will cure it. an oil seperator will be used.
anyone have any experience with one? is it continuous duty or switched on/off? we hooked it up and it sucks like hell
btw AC Delco #215-425 air pump
GM #12568324 it fit a '01 S-10 4.3
I'm sure there are other models that use it.
Old 01-12-2007, 06:10 PM
gixster's Avatar
you can use it but you have to turn it off after every pass or it will go bad very fast.I know some guys the use it and they replace it once a year.
Old 01-12-2007, 06:30 PM
Rusted40's Avatar
cool, thanks
so some sort of boost or rpm activated switch is a good idea
if it scorches easily then I have to assume it is probably computer controlled
any ASE GM specialists here?
Old 01-12-2007, 06:57 PM
gixster's Avatar
The guys that i know just tune it on after the burn out and shut it off after the pass.Nothing more then a toggle switch.
Quick Reply: evac system
