02 Sensors, help!!! Wiring q, really need help!
The wires on my front 02's have been cut, I can't find the wires at all, the front 02's are in place on the headers but aren't connected to anything and I can't find the wires they go to... does anyone have a wiring diagram for the computer so I can run new wires down to the front 02's, please help me!!! thanks!
I would recommend just purchasing a new set. Rigging up O2s isn't the best option, they don't hold up well over time. There is a harness on each side of the vehicle, the driver side harness is connected to the block right by the engine mount, the driver side harness is connected to the K member fairly close to the manifold/header primaries.
Although, you're 100% certain that it's the fronts? I can't think of any particular reason why someone would intentionally cut the fronts...
Do you mean something like this?
On the connector:
Right side (Passenger)
Pin
Wire Color
Circuit No.
Function
A
TAN
1667
Heated Oxygen Sensor (HO2S) - Low
B
PPL
1666
Heated Oxygen Sensor (HO2S) - High
C
BLK
450
Ground
D
PNK
539
Ignition Feed
Can't find the pin diagram for the left side (Driver's), but I think the following colors are correct
Pin
Wire Color
Circuit No.
Function
A
TAN/WHT
1653
LF Heated Oxygen Sensor (HO2S) - Low
B
PPL/WHT
1665
LF Heated Oxygen Sensor (HO2S) - High
C
BLK
150
Ground
D
BRN
241
Ignition (ON)
On the connector:
Pin
Wire Color
Circuit No.
Function
A
TAN
1667
B
PPL
1666
C
BLK
450
Ground
D
PNK
539
Ignition Feed
Pin
Wire Color
Circuit No.
Function
A
TAN/WHT
1653
B
PPL/WHT
1665
C
BLK
150
Ground
D
BRN
241
Ignition (ON)
The previous owner of my 98 did the same thing. My wiring is a mess. I just said screw it and bought a used 98 wiring harness complete. I cant even find the wires for the aftercat.
