Lean condition problem,Help
I finished another customers car,02"Ram Air stock 346ci,AFR 205s,Trak cam,Fast 90/90, pacesetters 1 3/4 full exhaust.We managed to pull off
422hp@6400 [email]385tq@4600. Afr locked at 12.8 thru 4800rpm then 13.2 till 6600rpm.Im not a professional tuner or anything but I can manage my own.I have one problem that doesnt go away,maybe some of the more experience tuners can chime in.I am having a lean condition occuring from 3600rpm till 3900rpm,goes up to 14.8 then I get a knock retard of -4 degrees AFR goes down to 11.00 then back up,finally AFR levels off to 13.2 at 4600rpm till redline.I have 26deg peak power and 23 degrees peak torque.I dont understand I lowered the timing,added more fuel,checked fuel pressure constant at 58-60,the most I seen drop was to 55psi.Anybody had this problem before?Overall the car runs great and smooth.I logged the dyno runs when this lean condition occured, O2s were at 945mv and 890mv.
A log would be good. Is this on a dyno run or under what conditions are you experiencing the condition? Did you tune the VE table? You may be experiencing some issues in transition from VE/MAF to full MAF fueling. I have some logged data demonstrating/showing very little AFR affects from huge timing changes (only .2 AFR change with timing varying from 9.5* to 36*). Besides, how does changing the spark alter the amount of air or fuel that entered the engine.
To post the file: under the area where you type in your message, there is a section titled 'Additional Options'; In there, you can 'Manage Attachments' HTH
