Cant get car into reverse
Old 01-14-2007, 12:07 AM
1fastTransAm's Avatar
Location: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
Default Cant get car into reverse
I replaced everything on the car about 2500 miles ago. Now I can not get it into reverse like it should. It took like 20min to get into reverse earlier today. The only other gear that is a pain in the butt is 1st. The reverse lights come on but gear does not engage. I am thinking of bleeding it again in case there is an air bubble in it. Dont really know what else to do minus pulling the tranny and replacing the throw out bearing which was new too. I have the Textrilla OZ700. So help???
Old 01-14-2007, 01:23 AM
I checked the fluid in the res. and added a little and it works again.. Its a pain to get into reverse but it now works.
Old 01-14-2007, 08:59 AM
Figz Z28's Avatar
My brother had a similar problem it ended up being the springs on the clutch. You might want to check the clutch it the problem continues.
Old 01-14-2007, 12:57 PM
99WS7's Avatar
reverse lock out switch...???
