Generation IV Internal Engine - What LS7 parts if any are compatible with the LS1?
02silvaZ
01-14-2007, 03:49 PM
I am curious for future plans if you are able to use any LS7 parts(i.e. intake manifold, heads, etc) on the LS1 platform, I am aware that the LS7 clutch and flywheel are compatible, but are there any engine parts that are compatible?
35thUCF
01-14-2007, 05:19 PM
the clips that hold the injectors to the rail
Wnts2Go10O
01-14-2007, 05:46 PM
ummmmm, the engine bearings, connecting rods, pushrods, bolts, main caps, oiling system,
camaronx
01-14-2007, 06:05 PM
the clutch i think if you use an ls7 flywheel i know on my ls2 gto it will work as i am gonna do it next week.
02silvaZ
01-14-2007, 08:34 PM
anything else?
DONAIMIAN
01-15-2007, 01:10 AM
everything will fit as long as the LS1 block has been knocked out to a 4.1 bore or bigger. If not, then everything except for the top end.
Ferocity02
01-15-2007, 01:41 AM
As mentioned, with a 4.100" bore or larger, LS7 heads will bolt up, and since the heads bolt up, then obviously so do the intake, fuel rail, valves, springs, rockers, etc... The passenger side valve cover needs to be modified to clear the LS7 rockers. You need longer pushrods if using LS7 heads on an LS1/6 block, mine came out to 7.750" long.
02silvaZ
01-15-2007, 06:09 PM
i apologize for not being more clear i meant what parts would bolt up without doing internal work like what you guys have discussed, i guess i got my answer as in nothing will, just curious if i had any options thru bolt-on parts, guess not, i guess the clutch is it
Cobras_Rule
01-16-2007, 07:19 PM
i also was curious about this but more along the LS2 aspect of things.
I guess my question is about the ls2 heads and intake. are they better then ls6 parts? and wil the ls2 parts bolt up without modification like the way ls6 parts bolt up?
thx im a noob to the ls2 stuff
TheLS1Kid
01-20-2007, 09:39 AM
LS6 and LS2 heads are both 243 castings. The LS6 heads have lightweight valves though. and for the intakes, the LS6 is better, but the LS2 will bolt up.
litle88
01-23-2007, 07:08 AM
Quick question. Will a stock LS7 intake fit a 2001 LS1, if so will I see any improvements? The reason I ask is because a friend of mine is selling me his LS7 intake really cheap, he is going to an alloy intake. Any help would be greatly appreciated.
TheLS1Kid
01-25-2007, 02:19 PM
no, you will need ls7 heads also, but thats not all, in order to use ls7 heads you would need more cubes. not worth it in my opinion unless you are gettin a bigger bore shortblock or something. hope that helped.
-Mike
