will high octane fuel hurt anything
I was wondering if running a mix of 93 and like 110 octane will hurt anythnig.
I will be using a 150shot of nitrous with racetronix plug n play fuel pump kit, and 42# injectors.
will this be ok to do, if not what do i need to do.
thanks
thanks
As long as it is unleaded you will be fine. The higher the octane the slower the burn rate is and less likely to detonate. If it were cheap enough I would run it all the time. Just make sure it is unleaded and you will be fine, it will not hurt anything only help prevent detonation or spark knock.
