to main stud or not to main stud, that is the question
Old 01-15-2007, 12:36 AM
lmt0705's Avatar
Default to main stud or not to main stud, that is the question
im looking at between 650 and 750 rwhp on my new build and I was wondering if I should go with an arp stud kit or if the stock bolts are sufficient. d1sc 14-16psi 346ci. patriot lq9 heads
Old 01-15-2007, 12:59 AM
Snyper's Avatar
yes def. stud. if you can afford to make 750rwhp then you can afford to stud it.
Old 01-15-2007, 01:12 AM
6techniques's Avatar
CYA at all times! Trust me, Ive learned that the hard way.
Old 01-15-2007, 01:17 AM
nvmy2000ss's Avatar
yeah you deffinatly dont want to short cut this part (heads to) I had to learn the hard way also on the heads.
Old 01-15-2007, 02:23 AM
Z06PSI's Avatar
Stud and girdle......
Old 01-15-2007, 02:54 AM
SuperZ's Avatar
I dont have any studs.Head or Mains and I have about 9k on my motor and I havnt had any prolems.If I did it over I would do them bothe though.My car is in the range of power also
Old 01-15-2007, 05:20 AM
JMBLOWNWS6's Avatar
I did it for what I consider cheap insurance!
Old 01-15-2007, 10:31 AM
bowtieman81's Avatar
I am not sure a girdle would be necessary at that level, but I would do studs. Aren't they $150 or so? To me that is cheap insurance as somebody else said.
Old 01-15-2007, 12:24 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
The side ARP main bolt kit that comes with the oil pump pickup tube bolt is only like 25 bucks I would do it too.
Old 01-15-2007, 12:34 PM
cablebandit's Avatar
i got studs but the 3 center mains still moved around some
Old 01-15-2007, 06:40 PM
Sawzall and Welder Mod
Whistler's Avatar
How can you tell they moved around?
Old 01-15-2007, 06:46 PM
you can see the mating surfaces when you pull it down
Old 01-15-2007, 07:24 PM
02SSLE's Avatar
if nothing else for peice of mind
Old 01-15-2007, 09:57 PM
Z06PSI's Avatar
Thats why I went ahead and bought a girdle with the longer studs. A little insurance with as much as we spend on motors.
Old 01-15-2007, 10:22 PM
BIG BAD BLACKSS's Avatar
I got main studs, head studs, and L19 bolts. Id hate to ruin a $8,000 motor over a snapped bolt!
