Weird noise!!
Old 01-15-2007, 11:09 AM
blkbird's Avatar
Default Weird noise!!
Ok, this started about three weeks ago. It makes a spinning (dont know how else to describe it) and I can feel it in the shifter, but only when the car is cold and at about 1k rpm in second and third on deceleration. It engages in all gears without any problems, but I have noticed that it engages rather rough. I noticed that my clutch reservoir was low on fluid(about 2/3rds low). I refilled it and has not gone down yet. The clutch isnt slipping either. I was wondering if the slave was going bad or the throwout bearing. Im stummped. Anyone have any ideas?? Thanks
Old 01-29-2007, 10:58 AM
blkbird's Avatar
Ok, the noise is getting worse. It will do it while in neutral now. Im baffled at what it could be. Anybody have any ideas?!?!?!?!
Old 01-29-2007, 03:05 PM
calhoon's Avatar
Sounds like a throw out bearing going out.
Old 01-29-2007, 05:16 PM
blkbird's Avatar
Wouldnt it be making noise all the time though??
Old 01-30-2007, 07:13 AM
calhoon's Avatar
It will if it goes on for long. These generally start as a squeeky kind of roll over noise cold.
Old 01-30-2007, 02:45 PM
LoudmouthWS6's Avatar
If you have the same problem that i did, which it sounds like by the way you describe it, i belive it was my pilot brearing, i replaced it and the noise was gone
Old 01-30-2007, 03:35 PM
blkbird's Avatar
What exactly were your symptoms and when was it happening??
Old 01-30-2007, 06:02 PM
I got the car in august and about mid september it started makin noise when i shifted gears and it also was kinda of hard to pull it in gear i would have to pull on it softly for a couple of seconds and then it would go in, i could even kinda fell it in the clucht, the noise sounded like something spinning like you said
Old 01-31-2007, 09:31 AM
blkbird's Avatar
Im just hoping is not the tranny again. Im gonna replace my slave as well.
Old 02-04-2007, 10:02 PM
blkbird's Avatar
ttt....Any other ideas??
