Likely Repost: How difficult is an LS2 swap (from a GTO) into a 1998 Trans am?
I'm sure this has been discussed before. Either I am inept at the search function, or I just don't know where to look.
Does anyone have any details about this? Is it worth the swap? If you have links or can direct me on where to look, I would greatly appreciate it.
If you're just doing a straight swap, then it does get complicated because of the reluctor ring on the stock LS2 (58X) is not compatible with the LS1 PCM's which are only compatible with a 24X reluctor. The cam sensor and knock sensors also present challenges, but are relatively easy to overcome because of the aftermarket adapter harness available from companies like Katech (sponsor here).
I believe all `05 LS2's use a 24X reluctor and are compatible (I read this in the GM performance parts catalog) otherwise Like said above the sensors aren't a big problem you would just need to set up the correct exhaust and a Cable operated throttle body.
Originally Posted by staringback05
because a 6.0l motor gives you a little more room to do things in the future then a 5.7l
