3.8L fuel injector size
What size are the injectors in a 3.8L camaro. A friend is having a hard start issue and it seems that the injectors are leaking into the cylinders. I dont know what size they are so I can swap in a new/different set to see if it helps.
Chad
Chad
depending on the yr of your buddies v6 the injectors may be rated at a diff fuel pressure.
have him hit up that link posted above and search away. if no answers are found to his liking then post up a new thread.
lots of v6 knowledge there.
