MS4 cam and stock block?
I have decided to use the MS4 cam but I was wondering if I go ahead and install it along with the stock heads and intake will this be ok until I get the TFS 215 heads(I really have to save up for those)but I will be installing pacesetters long tube headers,3" true dual exhaust with bullet mufflers,Yank PT 4000 stall,trans go shift kit,tranny cooler,dry nitrous kit, and I have a 02'WS6 T/A that all this going into!
Originally Posted by brad8266
you will be ok, but say bye to your low end power
Originally Posted by Mssingkid
The MS4 has some pretty good valve events, Low end power won't even be a concern since your going to run a 4K stall... I say go for it!!
What do you mean when you say it has good valve events? LOL, its like 238 intake duration, that valve closes so damn late you will lose plenty of DCR, which will make you lose low end. Put the specs in a dcr calculator to see what i mean. But with a 4k stall who cares anyway?
Otherwise, there is very very few ways to optimize DCR at 10.1:1 SCR, unless you want a tow cam
FYI, even the stock cam is not optimized for DCR, heck it doesn't even reach 8
Speaking of optimizing, who is gonna put 2.08 valves on a 3.905 bore???
Originally Posted by PREDATOR-Z
It has good valve events for the powerband it is designed for. It is by no means optimized for stock SCR, but the power it makes up high is like a screaming gorilla.
If 300lbs by 3000rpm not good enough, I wonder what the hell you are hauling in the trailer.
Im not sure what your goals are but thats not the cam id be using for that car....PM me if you have questions you want answered.
whats your combo?
232/234, .595/.598 113+0 degreed
PRC 5.3L stage 2.5, milled .025 (59cc), with race finish and platinum duals.
Bolt ons with a 2 stage dry+ supporting drivetrain
~11.88:1 SCR and 8.68:1 DCR
https://ls1tech.com/forums/dynamometer-results-comparisons/612494-cam-bolt-ons-417rwhp-w-ms4.html
01 M6 MS4, 160 Stat, TR55's, P&P Tb, Lid, K&N, Pacesetters, TSP ORY, Full Exhaust, 25% powerbond pulley, Free Mods
Most of the posts I've seen from people who actually have the MS4 are saying it's not got the low end that it was marketed and claimed to have. But I'm still highly intrigued by the cam. I can't wait to see LS144's car with that cam in it. Looking at valve events, I think there's a nice LSK lobed custom grind that would be all around slightly better within a usable powerband (<7000 rpm) by looking at the valve events.
