ARP rod bolts
ARP rod bolts
I've seen a lot of people install these.
Is it worth it? I'm down to the short block right now. Are these a week link or something?
I will have stock bottom end with around 11.3 compression, head & cam car.
If so don't you have to resize the bearing end of the rod?
thanx
thanx
Super Moderator
Re: ARP rod bolts
If you are there, then do it. Most of the rod issues we've seen have been associated with failed stock rod bolts I believe. Good insurance.
No ther mod's required. Just remove the stockers carefully and install the ARP bolts per their instructions. (i.e. torque and loosen twice, and then final torque down).
