Many Problems Help!!!
Old 01-17-2007, 09:32 AM
sport01!'s Avatar
Unhappy Many Problems Help!!!
i have a 2001 ss 97,000 miles. My ses light turned on starts flashing as soon as i hit 30 mph. I went to autozone to get a dianogstic the port was sending no reading to it .Probably a fuse not sure.Also it backfires when i start it up and ive benn burning alot of oil put in a quart 2 days ago and this morning low oil light turned on.If anyone has some advice i would greatly appreciate it.
Old 01-19-2007, 05:24 AM
SRT2LS1's Avatar
Wow man that sucks, wish I had an answer but I dont so I'll atleast bump it up!
Old 01-19-2007, 01:24 PM
staringback05's Avatar
check the compression on the cylinders....make sure a piston ring isnt gone
Old 01-19-2007, 03:43 PM
2001NBMZ28's Avatar
Flashing SES is a misfire for sure - no power at the DLC port is a blown "CIG/ACCY" fuse. Maybe the code will give you an idea which cyl it is, might just be a P0300 though, depending on what scanner AZ uses.
