Boost Ref FP Regulator of Choice?
Old 01-17-2007, 02:34 PM
ss1
ss1's Avatar
Default Boost Ref FP Regulator of Choice?
Just wondering what fuel pressure regulators (boost referenced) you guys are running with success? I'm just looking to get one with two inlet ports -6an, one return -6an, and a gauge port.
I've been looking around and see that some people have had issues with Aeromotive and others say they work fine. I know Nasty uses Fuelab regulators on some of his setups but haven't found too much info here on them. I know Magnafuel is in the mix too.
So, what are you guys running/recommend? Pros/cons?
Old 01-17-2007, 02:35 PM
Senior Member
Country Boy's Avatar
I have a Magnafuel.
Old 01-17-2007, 02:59 PM
sonicbaloo's Avatar
We run Aeromotive FP regulators on our high HP FI motors.
Chad
Old 01-17-2007, 03:07 PM
MIGHTYMOUSE's Avatar
get the CAS one that speed inc. sells
NA$TY-TA's Avatar
Aeromotive Pro Series here......
Old 01-17-2007, 03:23 PM
ABeasst's Avatar
Aeromotive dual -10 inlets -6 outlet that is transitioned into a -8 line.
Old 01-17-2007, 03:26 PM
SSilverSSurfer's Avatar
the only one that speed inc had on their website is the prof. products powerflo and i went ahead and ordered it. didnt see the CAS one
Old 01-17-2007, 04:30 PM
DaveSchott's Avatar
Weldon used to have the best FPR on the market, I imagine they are still a top part
Old 01-17-2007, 04:42 PM
Coal Mining Director
onfire's Avatar
I'm using Weldon. Rock solid psi without spikes.
Old 01-17-2007, 04:56 PM
ss1
ss1's Avatar
Which Weldon? I'm assuming the 2040 since they only list two. I like that you added the fact of no spikes.
http://www.weldonracing.com/2040.html
Which Aeromotive are you guys running? I was also looking at the 13109 since I really don't need anything bigger. It's really a matter of preference or opinion at this point. I appreciate all of the replies so far.
Old 01-17-2007, 07:44 PM
EGash's Avatar
I've never had any problems with Aeromotive.
Old 01-17-2007, 08:16 PM
DeltaT's Avatar
I have the big Aeromotive and I have been datalogging fuel pressure with a pressure transducer for ~2 months with only +-4psi variations in pressure under load.
Jim
Old 01-17-2007, 08:23 PM
smokinHawk's Avatar
the speed inc one has worked well for me
Old 01-17-2007, 08:36 PM
Schantin's Avatar
I'm using the aeromotive. Works well so far.
Old 01-17-2007, 10:05 PM
427's Avatar
I like the Weldon A-2040 for electric pump.
Kurt
Old 01-17-2007, 10:06 PM
ninetres's Avatar
I have a fuel-lab I got from Nasty Nate.
Old 01-17-2007, 10:21 PM
onfire's Avatar
2040 A FPR is truly tested when you pump a lot of volume through it and the pressure does not spike
Old 01-17-2007, 10:47 PM
1INSANEGTO's Avatar
Magnafuel here
Old 01-18-2007, 04:18 AM
SRZ
SRZ's Avatar
Fuelab here as well.
Old 01-18-2007, 06:15 AM
Senior Member
Ive never had a pressure flux or spike with my Magnafuel. Rock steady under vacuum and boost.
