what plug is this...
Old 01-17-2007, 05:54 PM
erikthegoalie's Avatar
Question what plug is this...
i got my heads today and I am bolting up everything....I am putting as many plugs in the back as I can..and I found two purple ones...one was longer than the other...I assume the longer of the two goes to the cam position sensor...where does the shorter of the two go? In the pic you can see one is plugged in and one is not, the one that is not is the shorter one...it may be simple though, what am I missing??
Thanks
Old 01-17-2007, 08:11 PM
LSWon00's Avatar
Appers to be the EGR conector which should be on the right side of the throttle body. If you can take a shot of the larger area it would be easier to tell, I can't really tell where on the engine I'm looking.
Old 01-17-2007, 08:12 PM
brad8266's Avatar
Looks like the MAP sensor connector to me. The sensor is connected to the back on the intake manifold.
Old 01-17-2007, 08:14 PM
LSWon00's Avatar
Yea MAP sensor is very likely...I just did the very same thing last week so I'm trying to remember.
Ok I see it now...to the right is the oil pressure switch.
Old 01-17-2007, 08:31 PM
ok cool guys....ill figure it out....reason I asked is because I deleted AIR, and didnt know if that may be a left over plug?!?!
went nuts unpluggins hit when I !AIR hahah
thanks
e
Old 01-17-2007, 08:32 PM
yeah BTW youre looking at the very back of the valley pan....against the firewall...
Old 01-17-2007, 09:03 PM
brad8266's Avatar
yeah, its MAP
