Fueling & Injection - just finished my dual intank walbro setup, pics
2002/Black/SS
01-17-2007, 06:53 PM
it looks pretty good to me, but kinda looks like the fuel socks are all in the way of the pumps, but i guess that will be fine. hows it look guys?
also thanks to EPP for sending me the stuff i need
http://i74.photobucket.com/albums/i247/yeshivahighsucks/PIC_0022.jpg
http://i74.photobucket.com/albums/i247/yeshivahighsucks/PIC_0023.jpg
http://i74.photobucket.com/albums/i247/yeshivahighsucks/PIC_0024.jpg
http://i74.photobucket.com/albums/i247/yeshivahighsucks/PIC_0025.jpg
http://i74.photobucket.com/albums/i247/yeshivahighsucks/PIC_0026.jpg
http://i74.photobucket.com/albums/i247/yeshivahighsucks/PIC_0028.jpg
SSilverSSurfer
01-17-2007, 11:39 PM
looks good to me, did you follow what Frost did basically? thats what im gonna end up doing. are you going with a bigger feed an return?
2002/Black/SS
01-18-2007, 02:05 AM
im doing this with stock everything. ill let u know how it holds up
onfire
01-18-2007, 09:20 AM
You can't use the stock wiring to run both pumps. You need a dedicated 12V feed with 10ga wire. You can use the stock wire to close a relay to the 10ga wire to keep the "key on" effect and safety features.
30 amp draw from 2 pumps will blow factory fuses, relays and possibly burn the wiring harness.
2002/Black/SS
01-18-2007, 12:59 PM
oops, i forgot to mention i have a racetronix harness that both pumps run off of and a hobbs switch to turn on the second pump
onfire
01-18-2007, 03:09 PM
Good move. I'm using their harness and the quality is super.
SSilverSSurfer
01-18-2007, 03:55 PM
good deal. i'll be waiting cause im pretty sure you'll be done with your car before me :(
Frost
01-18-2007, 04:48 PM
Looks good.... sure as hell hope you ditched that stock regulator for ne mounted up front that will work properly.
stealth71
01-18-2007, 06:24 PM
Is that fuel line going to hold up submerged in fuel? You should check it fairly often or switch to submersible fuel line.
Gates Submersible Fuel Line (http://www.gates.com/australia/brochure.cfm?brochure=3156&location_id=3779)
They sell it at Napa in 3/8" & 5/16". The 3/8" is #H213.
This is what I got:
http://www.bionicengineering.net/media/Photo0002.jpg
Jake@EPP
01-18-2007, 07:06 PM
The braided hose show in his pictures is the stuff we use for just about every pump install. We have had failures with just about everything else.
Slowhawk
01-18-2007, 08:12 PM
If the top picture is the finished product,cut alot more out.The pumps will cavitate like that. Found out the hard way before.
2002/Black/SS
01-18-2007, 08:43 PM
only those holes in that side, as u can see the back is completly cut out and the bottom is too, but i guess ill add more holes, couldnt hurt.
Frost
01-18-2007, 11:34 PM
I think Don just looked at the very first pic. With the bottom wide open and the back, there really is no chamber to cavitate.
stealth71
01-19-2007, 06:42 AM
I have seen pictures of badly deteriorated hose after only a couple months. The Gates hose is specifically made for being submerged in fuel. It has a coating on the outside as well as the inside. That's why I went w/ the submersible line. Just my .02.
stealth71
01-19-2007, 07:09 AM
This was some of what I was reading: fuel line deteriation (http://corral.net/forums/showthread.php?t=842357)
I know its a Ford, but same concept.
