Gears & Axles - 60' w/ 10 bolts
View Full Version : 60' w/ 10 bolts
kevins2000LS1
01-17-2007, 09:07 PM
Whats the best 60' times you guys have pulled with a 10 bolt. If possible best times with 4.10's
kevins2000LS1
01-17-2007, 09:10 PM
Post what tires (street or drag radials) you had and gears
2000LS1TA
01-17-2007, 09:11 PM
The Lower The Number, The Closer You Are To Having A Broken 10 Bolt :jest:
ssfast99
01-17-2007, 09:24 PM
1.67 with 4.56 with 27x10.5x16 ET streets. not even dumping clutch just babying it so it doesnt break but i heard someone got a nitrous launch with a stock rear and saw 1.4?. incredible
kevins2000LS1
01-17-2007, 09:46 PM
:hail:
kevins2000LS1
01-17-2007, 09:47 PM
1.6 and et streets and 4.56 damn you got a horseshoe somewhere sounds like
JNorris
01-17-2007, 09:49 PM
My best 60' is 1.48 and my average 60' is around a 1.53. This is with 3.73 gears and drag radials.
John
kevins2000LS1
01-17-2007, 10:01 PM
I see your a A4, im a M6 that makes a little differnce. But thats still some great 60" on a 10 bolt, :hail:
zspot98
01-17-2007, 10:03 PM
1.61 on 150,xxx mile stock rear and 100% stock susp & 2.73. I am an A4 though, so a lot easier then dumping your M6.
fastlane02
01-17-2007, 10:12 PM
1.62 WITH 4.10 's with auto. drag radials
kevins2000LS1
01-18-2007, 05:03 PM
1.61 on 150,xxx mile stock rear and 100% stock susp & 2.73. I am an A4 though, so a lot easier then dumping your M6.Got to love the old M6 and 10 bolts
sidewayz28
01-18-2007, 07:36 PM
i think all of these times are for autos :jest: not too suprised no ones responeded with m6
gillbot
01-18-2007, 08:31 PM
1.66 with 3.42's in an A4
dabe
01-18-2007, 08:34 PM
1.46
150 shot outta the hole
http://myspace-971.vo.llnwd.net/01166/17/92/1166412971_l.jpg
edit....a4...3.73s 275/50/15 mt dr
camscam02
01-18-2007, 08:36 PM
1.57 w/ 4.10's and drag radials! auto though!
red fury
01-18-2007, 08:45 PM
several 1.75's M6 Nitto DR's 275/40 17"s 4.30's 10bolt......babying it out of the hole.
many 1.80's same car and tire with 4.10's ......babying it out of the hole.
oh, and my car is lowered.
times in sig are with Motive 3.90's in the 10bolt.
edwardswb
01-18-2007, 08:49 PM
1.80 with M6/4.10s/et streets/fried clutch babying it
BlwnTA
01-18-2007, 08:56 PM
A4 1.60 with 4:10's and 27 x 11.5 x 15 Hoosiers
M6 1.74 with 3:42's and 275 x 40 x 17 MT DR's
ssfast99
01-18-2007, 09:06 PM
am i the onloy one to see 1.6 60' with a M6. i can send you the footage of the pass with the 1.6 sixty foot. car weighs 3520 with me and makes 410 rwhp and 365rw torque.cant wait for the 12 bolt
kevins2000LS1
01-18-2007, 09:46 PM
DAMN thanks for the input guys i run a 2.20 60' on street tires and 3.42 thinking of some 4.10s and drag radials but was kinda ify about busting my ole 10 bolt been down that road on a previous LT1. But dont look like the LS1 are a harsh on the 10 bolts as the LT1 are.
azceta
01-19-2007, 12:13 AM
ranges from 1.6-2.1 depends on how the clutch wants hook sometimes she's sticky and others she feels like a mexican whore
LorcinLs1
01-19-2007, 07:50 AM
1.46
man are you luck, I pulled a 1.57 with out spraying out the hole and that was it. the next pass when i launched i broke 6 teeth clean off the ring.
kevins2000LS1
01-19-2007, 04:43 PM
yeah send me the video kevinsz7198@aol.com
BlackScreaminMachine
01-19-2007, 04:46 PM
3.23's on Nittos 1.71 60 foot.
kevins2000LS1
01-19-2007, 05:22 PM
im hoping i can cut some 1.80 that woud put me @ a 12.80 with nothing but a 1 chamber flowmaster
SuperSport4life
01-19-2007, 05:24 PM
I did a 1.77 60 ft with a stock 10 bolt with an m6 with just bolt ons and 350 rwhp. I did it with 275/40r17 mickey thompson drag radials
BriancWS6
01-19-2007, 05:56 PM
1.7s on Nittos with stock suspension and 4.10s....m6.
1.6s on Nittos with stock suspension and 3.23s....a4.
00SS4780
01-19-2007, 06:04 PM
M/T drag radial (275/50/15)
430 gears and 6 speed
1.61 on motor @4700rpm
1.53 on a 100 shot @3500rpm
that was a spec III clutch and slipping it.
kevins2000LS1
01-19-2007, 10:33 PM
Thanks for the input guys what RPM's where you'll leaving at ???
Matt D
01-19-2007, 11:47 PM
Consistant 1.4X all day long. N/A, leaving off a 4000rpm foot brake.
lt1383
01-20-2007, 12:38 AM
I know 4.10
BUT HERE MY BEST ON '342'
1.5 60' 100 shot ..28' tire
kevins2000LS1
01-20-2007, 08:24 AM
will looks like some good 60' can be made with a 10 bolt just dont know how long they will last
gillbot
01-20-2007, 09:26 AM
Yeah, it's a crap shoot with the 10 bolt at best.
ssvert99
01-20-2007, 10:26 AM
1.48-1.49 w/ mickey's. 3400 vig., 4l60e, 3850# 'vert. leave just off idle and flash into the converter. front tires come off the ground about 3-4 inches
kevins2000LS1
01-20-2007, 11:49 AM
i got some 315 sumitomo's right now and going to 4.10's i think its going to be real interesting. they dont do bad now with 3.42 gears but the 4.10's probably will toast them
red fury
01-20-2007, 01:06 PM
Just above idle....1200-1400 with a quick slip of the clutch. I also think that clutch choice is a MAJOR part of getting descent 60' times and allowing the 10bolt to live. I had the 4.30's in the car for 1.5 years without breaking anything. You need a clutch that is forgiving, not a on/off style when running a 10bolt.
99zman
01-20-2007, 01:42 PM
it says in your sig 3:90's now why did you switch from the 4:30's? how do you like the 3:90's?
BrianC98Z28
01-20-2007, 03:20 PM
around 1400-1500rpm to load suspension. 1.49 spraying 150 outta the hole. A4 with Vig 3600.
kevins2000LS1
01-20-2007, 04:16 PM
yeah im going to need a clutch. what kind of clutch you running
red fury
01-20-2007, 05:05 PM
I was running the 4.30's N/A
Then I wanted to play around with N20 so the 4.30's came out and 3.90's went in, I didn't want to be forced to run a larger tire to get through the traps in 4th.
I run the Ram PowerGrip HD with the 300 series friction material disk....engages smoothly and holds great for my hp & tq levels on the Nitrous. The pedal pressure is firm but fine for a daily driver, to me that is.
engineermike
01-20-2007, 07:56 PM
1.52 on ET-streets. 3.42 gears and an A3.
kevins2000LS1
01-22-2007, 07:25 PM
im thinking i might keep my 3.42's in for a while and save for some 4.30 in a 9"
Z28/2002
01-27-2007, 08:23 AM
Check the sig for the 60fts on the Z28. Car had stock 7.5 with 3.42s. The CETA has been 1.8Xs on 16" Nittos running a 12.8X with a lid and Slowmaster. It's a stock geared 6spd
miamifan3413
01-28-2007, 02:41 AM
Damn, I've had 4.30's in for about 2 months & no issue's at all, 10 bolt is holding up fine......getting ready to get some ZR1 17" 285/315 combo.....the key is slippin the clutch with the 10 bolt......need to get some track time in:)
02WS6Bird
01-28-2007, 08:37 AM
for you guys spraying out of the hole (seems to be A4's) or cutting -sub 1.5/1.6 60's what all is done to your 10 bolt, stall, what tires, and what suspension?
working4toys
01-28-2007, 09:57 AM
darn good numbers
02WS6Bird
01-28-2007, 12:28 PM
anyone?for you guys spraying out of the hole (seems to be A4's) or cutting -sub 1.5/1.6 60's what all is done to your 10 bolt, stall, what tires, and what suspension?
