Fuel System Setup
Fuel System Setup
What's up- trying to figure this out. I have a 95 Z28, LT1 with factory Fuel System(send/return lines on Rails). I am looking into putting a built LS2 into it. We are trying to figure out how to setup the Fuel System. Is there a way to adapt the early F-body LS1 Fuel Rails with the send/return lines on them to the stock LT1 System, or will I have to pretty much get everything LS1, and run with that. I have a Fuel Pump Acess Panel already made, so messing in that area is no problem..
9 Second Club/LS1TECH Sponsor
The easiest and cheapest way would be to get the 99 and up Corvette filter/regulator and hook your LT1 lines up to that. Then just run a real short line from the output of the regulator to the LS1 fuel rail. The Vette filt/reg already has the correct fittings on it for the LT1 fuel lines.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
