Verify my pushrod calculation please
I measured the new cam lobes with my caliper. Heres what I got for what I need for pushrods. Figured another set of eyes on this would be good for verification. Thanks guys.
Stock cam base circle- 1.553
New cam base circle- 1.450
Stock pushrod length- 7.400
Length needed = ((stock base-new base)/2) + stock pushrod length =
((1.553-1.450)/2) + 7.4 = 7.452 for new rod length.
I would run 7.425
Your calculation is correct but stock p-rod length is not 7.400
since average stock preload is in the .100 neighbourhood and 7.450 would put you over that, the next best choice is 7.425's
Originally Posted by PREDATOR-Z
I would run 7.425
Ok thanks man, yeah ill go down to the 7.425's so i dont put too much preload on the lifters. I just didnt want too short rods so because i want to eliminate as much valvetrain noise as possible.
Actually now that i thought of it, I am going with a .034 gasket and hope to be able to mill the 5.3L heads .030, so this will bring my rod length back up some, close to stock size.
So 7.39 stock + .0515(base difference) - .018(difference between stock and new head gasket) - .030 (head mill) = 7.3935
The 706 5.3L cast heads unmilled do keep the same height as LS1 heads right?
What is your piston deck height? .034 gasket seems tight unless pistons are 0 deck or below.
And with all the variances you're playing with better get a push rod length measurer.
Originally Posted by brad8266
Yeah i was gonna get the checker anyway most likely. I believe they are out the hole .006, it would be a tight quench area. The motor is being clayed before any milling to determine how much i can mill. I have -2cc diamond pistons with eagle 6.125 rods, stock crank.
Look at .040 gaskets (Cometic) or Mr. gaskets are .042 (but 4.100 bore)
If true then your quench is at .028, way too tight for a street application.
