After H/C install how bad will the car ride w/o tune
I will be installing a H/C this weekend, cam is Torquer v3 also installing a Yank SS4000. How bad will my car ride without a tune since I want to break in the TC (150 miles) before I get a tune.
LS1 Tech Administrator
Your car is going to run like dogshit, especially at idle. That cam is going to want at least a 900 rpm idle and a 550/650 rpm idle coupled with stock VE tables is going to possibly foul out your plugs, whack out your O2 sensors and you'll be getting misfire codes from hell from the cam and converter. Bad way to break in a converter IMO. If it's a money thing, I can understand why you may have to wait. If you think it's the right way to do it, you would be mistaken.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
It is not a money thing, but I was thinking that the TC has to be broken in (on Yanks website it states a 150 mile break in period) before I take it to a dyno and they lock the TC up to program the car. If I am wrong then I will get it tune after the install. I have never had a car tuned before nor have I put H/C on a car so I do not know what to expect.
Have you done the H/C swap yet? If not then put the converter on now and break it in for 150 miles, then install the Heads and Cam, heat cycle the springs and dyno tune the car. If you have already done the H/C swap then just have it dyno tuned with the 3500 Converter in your sig. Good luck with the install.
AJ
AJ
Im in the exact same possition i want to have my SS4000 and torquer v.2 installed at the same time and tuned but the converter needs 150 mile break in before going WOT so no dyno tune until then. Im thinking possibly have them tune it at idle so it will at least start and idle ok for the first 150 miles and then have it dyno tuned.
AJ
AJ
Originally Posted by N4cer
Just do one then the other. What's so hard about that?
Most mail order tunes only address the WOT details, not the driveability details. The driveability is where you're going to take the big hit without a tune.
__________________
Location: Your girl's back door giving her the long stroke while you're at work
A mail order tune can never be right unless it's totally coincidence. There's no way to know exactly how every car is running, and the climate of your location.
