Which K member for an ls1/fox swap?
Old 01-20-2007, 06:48 AM
Crawlin Z's Avatar
Default Which K member for an ls1/fox swap?
I was all set to use an AJE w/ interchangable mounts(you can get for an LS1), but I see some people saying you get great engine setback w/ a 94+ 4.6 K member. Is anyone currently using the AJE LS1 K member, how close does your motor sit to the firewall? Thanks
Old 01-20-2007, 11:36 AM
vanilla89's Avatar
i belive there are people running the aje k-member,and they say the motor is about 3 to 4 inches away from the firewall.mines about a 1/8inch from the firewall,i have a qa1 96-04 k-member
Old 01-20-2007, 12:24 PM
Restricted User
NBM2001z28's Avatar
PA Racing makes the best K-member you can buy! PM me if you need any help or if you're looking to have anything done. I beleive I'm going to be building myself a 347 Turbo LS1 Notch here this winter
Old 01-20-2007, 01:18 PM
PRAY HRD's Avatar
i agree, use the 4.6 and make your own mounts.
PRAY HRD's Avatar
Do it man!
Old 01-20-2007, 03:38 PM
ls1stang's Avatar
I used the QA1 96+ k-member in both of mine with no problems. I just sold my 94, and now I'm buildimg a 98 with a 347 single turbo setup.
Jamie
Old 01-20-2007, 04:33 PM
Crawlin Z's Avatar
What did you do for motor mounts and headers?
Old 01-20-2007, 04:48 PM
Brains's Avatar
The 96-98 AJE K-member (not the Fox 4.6 swap unit, the actual 96-98 unit) sets the LS1 about 3/4" off the firewall. Its as far set back as you can get without actually modifying the firewall. Perfect, in my opinion.
Old 01-20-2007, 05:28 PM
lt4malibu's Avatar
doesnt the 4.6k-member for the 98-98 cars set the front wheels back in the wheel openings? i thought i read somewhere on here that it did?
Old 01-20-2007, 07:45 PM
Brains's Avatar
Forward in the wheel openings, yes. It hasn't proven a problem for me at all though, wheels still fit just fine and don't rub. I did need to extend the steering shaft, but that's pretty trivial.
Old 01-21-2007, 12:39 AM
vanilla89's Avatar
i had to cut the front of my finders so my wheels would turn,but my car is really low and on 20's,the 17's i have still woulden't fit
Old 01-22-2007, 07:22 AM
Vcious04's Avatar
I am using AJE tubular K for 4.6 swap for foxbody. I am also using stock 4.6 motor mounts with the single side of the mount extended about an inch. Fit perfect in my opinion, esp when you can re-use the factory adjstable crossmember for the trans with no modifications but the bolt holes for the mount.
Also I have about 3/4" space between the k-member and oil pan.
Old 01-22-2007, 04:40 PM
ssmr0501's Avatar
Just recieved my custom k member from AJE made for LS1 fox swap. It has options of moly / mild steel construction with solid or poly motor mounts. Only downfall is the 4-5 week build time. Well worth the wait there is at least 3/4 inch clearance across from the oil pan and it sits about 1 1/2 - 2" from the firewall. My cost was $559 shipped moly / with solid mounts Perfect Fit
Quick Reply: Which K member for an ls1/fox swap?
