JL ws-6
01-20-2007, 02:17 PM
I'm running a 402 ci motor setup right now with a set of 42 fms injectors, and a single intank racetronix pump.
I am planning on adding a plate nitrous setup.. will I be o.k.. spraying a 100 to 175 hit thru the plate, with the fuel coming from the stock rail? Shoudl I add a boostapump to the racetronix harness to be safe?
If anyone's been down this road, please post up. I'veheard of the nitrous activation causing a drop in fuel pressure, but I dont' know at what level they were having the problem. I'm currently making about 450 rwhp (thru a 6000 converter and a th400) and on the spray I suspect it to be in 600ish range.
