how much can a 241 head be milled with a MS3?
Old 01-20-2007, 04:14 PM
chrs1313's Avatar
Default how much can a 241 head be milled with a MS3?
Is this a good idea any negative affects how much will power increase over non milling? thanks
Chris
Old 01-20-2007, 04:55 PM
GuitsBoy's Avatar
Chris
MS3 is a big cam and is already pretty tight piston to valve. I dont think youll be able to mill at all without flycutting. I highly suggest notching the pistons. Youll gain a bit of power, but more importantly, youll gain a lot more low end torque and drivability with the higher compression.
Old 01-21-2007, 04:34 PM
chrs1313's Avatar
how can a 5.3 head be about at the max with stock gasket for piston to valve clearance and a stock head be the same...i guess how much of a difference are we talking between stock heads 241's and 5.3 heads...because i know for a fact that 5.3 with a stock gasket is about the closest you wanna go...
