Head/cam PTV question for the guru's ..
Old 01-21-2007, 02:08 AM
DeviLs1's Avatar
Default Head/cam PTV question for the guru's ..
Okay , My cam thats in the car is a comp 232/238 .574/.586 and on a 112+4
Okay with that out of the way, ive recently had a chance to buy some Ported 5.3 heads,.. Am i pushing it running these heads without any milling ..Can i just run a slightly thicker head gasket. ?
I dont want to destroy my motor 3-4 months later down the road from adding heads.
Any input is appreciated...
Old 01-21-2007, 02:40 AM
cowboysfan's Avatar
are the heads milled? if not then .040 gasket would work. clay it for peace of mind.
fuerzaws6
Old 01-21-2007, 02:47 AM
DeviLs1's Avatar
No the heads are not milled.. running a thicker head gasket also raises the CR ?
Old 01-21-2007, 05:55 AM
PREDATOR-Z's Avatar
fuerzaws6
No way.
If ported those heads have bigger valves, which reduces PTV. Your problem will be on exhaust valve
