Sluggish car with low CR
Old 01-21-2007, 01:59 PM
Runn's Avatar
Default Sluggish car with low CR
I have a question for you
If i lower my CR to 9:1 how sluggish will the car feel compared to a stock LS1 if i start from stop... What are youre experiences with boost and a lower CR. I know this depends on a lot of factors but i´m only looking for some info
Thanks.
I´m going to have a Inconkit on my car with two GT3776R.
Old 01-21-2007, 02:29 PM
02SSLE's Avatar
my car with forged 347 was really sluggish till I figured out how to take off. I have to rev to 4500 rpm and dump the clutch and then I would imediatley have boost. the CR was 9.1
Old 01-21-2007, 03:22 PM
bad95killer's Avatar
Not 346ci but my buddy's Y2K C5 M6 equipped with 408ci the CR dropped down to 8.7:1 for 300+shot moves damn well & ya can say better than full bolt-ons LS1 esp. from low roll or dig so i don't think that considered to be sluggish,Btw he has 3.42's & he spinning thru 1st 'n 2nd on street tires damn hard
Anyway keep us updated with progress
peace
Old 01-21-2007, 05:48 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Figure a 3% decrease in power from 10:1, that's nothing to worry about. It's the bigger cams that make forged engines feel like they lack low end.
Old 01-21-2007, 11:39 PM
gametech's Avatar
Sounds like someone has good plans for Josh's old Incons.
Old 01-22-2007, 12:31 AM
mdhmi's Avatar
My CR is in the high 8's and don't have any problems with partial throttle umph. Properly sized torque convertor is priceless.
Old 01-22-2007, 01:25 AM
LSs1Power's Avatar
My 408 has a 8.4 C/R and it doesnt feel sluggish at all. It dyno'd 430rwhp 450rwtq on a Mustang dyno N/A. It is still running the LS6 manifold with stock TB too.
Old 01-22-2007, 05:37 AM
2002/Black/SS's Avatar
i saw no difference after i put on my 6.0L heads, no lose but no gain
Old 01-22-2007, 09:19 AM
TurboGoat's Avatar
I hope this stuff is true, I am setup to have an 8.8 to 9 ratio and I am hearing from some people that it might feel like a dog off boost, hope not.
346 with T76MPS turbo. I am going to run my vig 3200
Old 01-22-2007, 10:05 AM
camarols1's Avatar
If the car is tuned properly with a matched converter you will be fine.
Old 01-22-2007, 10:44 AM
Runn's Avatar
Only a 3% drop if i lower to 9:1, dont sound so bad... 350-3% = 335-340.
Old 01-22-2007, 01:40 PM
LS1Tech Co-Founder
That's the number I have seen a few times, 3%. Even if it's 5% it's still not bad.
Old 01-22-2007, 01:50 PM
High on diesel fumes
thunder550's Avatar
Big on this. My 408 sucks coming out of the hole. I'm 9.5:1 SCR, about 7.0:1 DCR with the cam I'm running. Built the motor for boost, but running it N/A for now. Best I could pull at the track was a 14.89 @ 97 with a 2.4 60'. I had a stock 6.0 with a Radix at 7 psi before and ran a 13.66 @ 104, 2.05 60'. I was hoping to be close with the N/A 408 but it's just a dog down low.
Old 01-22-2007, 04:23 PM
LS1Tech Co-Founder
My DCR on boost is huge it's like 17:1, are you na right now with that truck?
Old 01-22-2007, 04:37 PM
thunder550's Avatar
Yeah for now, hoping to have a turbo on it sometime in the next 6 months or so. Even if I could hit 20 psi I'd still only be 16:1 DCR.
Old 01-22-2007, 04:51 PM
7 Second Club
Phil99vette's Avatar
I think the key to low compression is having a good set of heads on the top end to make up for it. My next combo is going to have 8.0:1 CR but topped with some bad boy ET LS7 heads flowing over 350cfm.
Phil
Old 01-24-2007, 11:09 AM
Runn's Avatar
Thanks for the answers.
Old 01-24-2007, 11:15 AM
Fire67's Avatar
We just put together a 8.25:1 355 Ltx motor for my buddy's turbo project. We installed the motor without the turbo to do break-in. On a stock tune, AFR 195's, stock injectors, LT4 intake - extrude honed, and a baby turbo cam, the car pulls waaayyyy harder than the stock full bolt-on Lt1 did.
Im sure its not making as much N/A power as it could if we had left the compression alone, but its still not sluggish by any means. Once the turbo gets here it'll be on!
Old 01-24-2007, 11:17 AM
anarchy99's Avatar
I ran my car for awhile with the wastegates setup so no boost would come on. (engine break-in) 8:5-1 compression ratio. Not sluggish like you would think. Car drove like it did before I put everything on it. Now that it's in boost it's awhole different story!!!
Quick Reply: Sluggish car with low CR
