Turbo Stall
Turbo Stall
I know this isnt the trans section but what converter and size are most of you turbo guys running.Im ready to buy one.I want somthing that will leave good,hold power,and not drive to bad on the street.Its for a th400.Ive been pretty set on the Pro Yank 3400.What do you gusy think.I have 3.42s gear and a 325/50.15 DR.thanx
I called Yank. They set me up with a SC3000 stall for my TH400. I am going to run 3.25 gears also. I wanted something that was nics on the street but a good performer at the track. This is what they said I needed. I have T-brake too so that should help at the track.
Hmm thats wierd.Im running a truck manny kit like your setup will be but with a larger GT-42 turbo.The guy at yank told me I should go with the pro yank 3400.I didnt know if that would be to much.not enough,or just right.Im new to the auto turbo stuff.I have a trans brake also.
I'm starting piece my turbo setup together and I was leaning towards a 3000-3200 stall. Figured I'd need to keep stall speed low for the turbo torque curve. Found a VIG 3000 in the for sale section so sounds pretty good............
