some clinking upon rev...?
Old 01-21-2007, 09:50 PM
toofless916's Avatar
Default some clinking upon rev...?
as im cruising at about 45 mph i take my foot off the gas and tap it real quick...my engine revs and right before the power shoots the the rear there is like 3 or 4 clinks real close together coming from (what sounds like under the car towards the rear)...i can only hear this while im cruising at that speed...any faster and i cant hear it and any slower my exhaust mutes all other sounds...
any ideas what this is?
Old 01-21-2007, 10:12 PM
1987firechicken's Avatar
What kinda tranny you got? Need more info about your car.
Old 01-21-2007, 10:17 PM
99 T/A stock A4 with 64k miles...so what do you think is the problem?
Old 01-22-2007, 12:18 PM
anyone?
Old 01-22-2007, 06:44 PM
well i found the culprit...its the passenger side exhaust tip where it is hung on my frame...that **** is loose or something and when its jolted back and forth it makes some crazy metal to metal sounds...dont thinks its a serious issue and i aint gonna worry about it unless someone tells me its a problem.;..
Old 01-22-2007, 10:54 PM
99z28monster's Avatar
aint a problem so dont worry about it, just make sure that is the problem
Old 01-23-2007, 09:45 AM
has to be...the sounds almost match up...i guess if its something else imma find out later on down the road...
Old 01-24-2007, 01:25 AM
wow....how incredibly wrong i was about that squeeking...its actually coming from somewhere around my belts in the engine...and its only squeeking upon revs...idles fine...cruises fine but at low revs its "squeek squeek squeek" and at 50 mph i punch the gas and its a quick squeek then goes away...
Old 01-24-2007, 08:12 PM
try checking your serpentine belt,
