Does this look right..add/remove?
Old 01-22-2007, 10:48 AM
7th Darkness's Avatar
Question Does this look right..add/remove?
I am doing a LS6 swap into my 98 T/A Convertible, A4, with 3.90 gears.
I am about to place an order for some new parts, tell me if I am missing anything for a cam swap and tranny upgrade..
Cam
1. Comp Cams Xtreme RPM 224/228 .534/.537 112 LS, (2000-6800 RPM)
2. Crank Pulley Bolt
3. LS2 Timing Chain
4. Patriot "Gold" Dual Valve Spring Kit
5. Comp Cams Hi-Tech One-Piece Chromemoly pushrods, 7.400"
Tranny
1. TCI 4L60E Super Street Fighter 3000 Torque Converter (edit)
2. V8 B&M 4L60E Transpak Shift Improver Kit
3. New Torque Converter, Flywheel, Pressure Plate Bolts
Anything I might want to change or add please let me know.
Thanks!
Old 01-22-2007, 10:52 AM
ArcticZ28's Avatar
Depending on the mileage on the motor, might want to pick up a new oil pump while you're in there - either a ported LS6 or a melling. Also might want to pick up a front timing cover gasket.
Old 01-22-2007, 10:58 AM
LSWon00's Avatar
Is that a 4000rpm stall? If so I would reccomend calling TCI to see what they say to match your cam and setup. I have a similar setup 224/228 .585/.585 114 with a loose Vigi 3800 and I want something smaller like 3200. People told me go no lower than 3600 but it makes for lower mpg and my converter isn't matched well for my cam. You'll get used to it but I would talk to the converter manufacturer and go with what they say not what others tell you.
Also you'll need hardened push rods and gaskets. Lifters depending on the mileage and age of your engine. My stock lifers started giving out and I bought the new Crane lifters that are like the Morel ones.
Old 01-22-2007, 11:11 AM
The engine is an 04 and has only 21,000 miles.
Are new pushrods really needed?
Old 01-22-2007, 11:19 AM
ArcticZ28's Avatar
If you're going to be revving anywhere near 6k, I would say so.
Old 01-22-2007, 11:24 AM
Called TCI... good thing I did... only need 24/2500 to match cam. SO could I go with a 3000... closest vendor has?
New push rods added.
