L92 Heads/L76 Intake
I think those are the model numbers...
Has anyone install them without porting? Basically going with a cam only LS1 then bolt those heads/intake on?
I am wondering how much more power i'll see from that setup on my stock LS1.
You will loose all power, as the intake valve will collide with the LS1 cylinder wall. You can not use those heads with anything smaller then a 4.00" bore, the intake valve is 2.15".
