How Much Boost and How Much Power with 10.2 Comp Ratio
Old 01-22-2007, 04:33 PM
GTO30272's Avatar
Default How Much Boost and How Much Power with 10.2 Comp Ratio
I am getting anxious of course with winter being here and curious on what you guys think. My setup unfortunately will have a lot more compression than I would like, but that is how it must be for now. So my question is, how much boost do you think I will be able to safely run and what kind of power do you think that it will make. Thanks in advance.
3.905 Bore
4" Stroke
71cc professionally ported/polished LQ9 heads with Comp 921's and inconnel valves
GM .052 MLS Gaskets
233/239 114 Cam
-7cc Diamond Pistons
Piston to Deck -.015
Rear Mounted Precision 76GTS Turbo
Meth Injection
75lb Injectors
255 In Tank Pump
2nd 255 External Pump with secondary lines
93 pump gas
Old 01-22-2007, 04:45 PM
GTO30272's Avatar
not sure if it matters but this is in a Z06 with the MN12 trans and 3.90 gears. Thanks in advance.
Old 01-22-2007, 06:24 PM
lmt0705's Avatar
thats going to depend on how good your tuner is and how safe you want your tune. are you intercooled or just meth injection, that will have an effect on your inlet air temps and also effect how much boost you can run safely.
Old 01-22-2007, 07:33 PM
GTO30272's Avatar
The tuner has been in the business for many years and I have a lot of confidence in that department and yes, there will be a Bell single front mount intercooler in addition to the meth injection. Thanks for your response.
Old 01-23-2007, 07:48 PM
GTO30272's Avatar
t t t
