Small Block & Big Block Chevy Specific - max cam lift for 350?
View Full Version : max cam lift for 350?
98vortecbw
01-22-2007, 04:34 PM
ok, my dad has a '70 chevelle malibu with the BONE stock 350, and im just wondering what is the maximum lift the stock heads can take? thanks.
jmm98LS1
01-22-2007, 04:40 PM
You should replace the springs regardless, they're 37yrs old. Personally, I'd stay around .500" or less with pressed in studs. Any lift above that isn't going to help much unless you have the heads ported.
98vortecbw
01-22-2007, 04:47 PM
were actually putting ported camelhumps on it also, so how big could we go then???
Studytime
01-22-2007, 05:17 PM
What diameter spring are you running?
Ben T.
1989GTA
01-22-2007, 07:26 PM
It depends on what you do with those heads. With the right springs and valves you can go pretty big on the lift. Stock I would say .470" total lift might be pushing things. Best to measure though. Two things to check are coil bind and valve seal clearance.
