Fueling & Injection - Should i get bigger injectors?
View Full Version : Should i get bigger injectors?
478TAM6
01-22-2007, 08:33 PM
ok im uppin my boost to 15 to 16 psi and puttin a methanol kit on and only have 38 lb injectors.Will i need to go with some bigger injectors or will they be enough?
Hodgesz28
01-22-2007, 08:50 PM
Id get some 42's, thats what I had when I was running my D1 and running 12psi and it was plenty.
explorer5.0
01-23-2007, 08:17 AM
You WILL need larger injectors, and 42's wont cut it. The 42's are good to about 500whp, and you should be well past that on an LS1 at 15psi.
478TAM6
01-27-2007, 09:57 PM
yeah i think i will get bigger injectors.any more input anyone?
RedHardSupra
01-27-2007, 11:02 PM
yes, for any FI setup you need a manifold referenced fuel pressure regulator and a return line. also you need a much bigger pump. give AZPS a call, they got some very nice fuel systems, and they do a lot of FI.
Jake@EPP
01-28-2007, 01:22 AM
For 15-16psi on a procharger i would reccomend ATLEAST 60lb's, we sell these for $419.99
