Predator -- go negative on slope, means need to go positive in PE ??
LS1Tech Sponsor
When using the Predator and adjusting the injector slope -- if I had to go negative on slope (cuz I had + trims), does that mean I need to go positive (rich) in the PE ranges??
I've seen conflicting statements...
...the Diablo book and RWTD site say that if you have positive trims - you go negative on injector slope (to zero them out) and you need to LEAN OUT (go negative) in the PE ranges as well.
...but I've read online forums where users say that when they go negative on injector slope, they need to go positive (rich) in the PE ranges.
So which is correct??
Thanks!
p.s. - at WOT, my trims lock at 0, my stock O2 is 860-880, and AFR is 12.2-12.6
Thanks!
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
LS1Tech Sponsor
ok, got the scoop from diablosport (Johan's tuning doc)... basically yes - if you go negative on injector slope, you need to go positive (rich) in the PE ranges by the same amount -- and vice versa.
so the manual says the opposite, and is wrong.
__________________
I talked to mike the other day and that about what he had told me. Run the injector slope - to correct any positive STFT or LTFT's and then use the enrichment function to help zero in the LTFT's.
I am still waiting on them to tell me exactly what the injector slope function does to the tune.
LS1Tech Sponsor
positive injector slope makes the pcm think it has larger injectors and thus reducing the pulse width to supply less fuel.
__________________
