LS6 or 5.3 Heads
Old 01-23-2007, 08:59 AM
FU_I_AM_UltraZ's Avatar
Default LS6 or 5.3 Heads
Which are the better heads for a car that is a weekend driver and sometimes during the week depending on weather. I was looking at patriots stage 2 LS6 heads, but read that swapping to 5.3 heads immediately add hp b/c it raises the compression ratio?
Old 01-23-2007, 09:01 AM
brad8266's Avatar
The LS6's flow better, you can just mill them too if you want to up compression. If I had to take a stock LS6 vs stock 5.3, id go with the LS6.
Old 01-23-2007, 07:44 PM
okay..thanks
Old 01-23-2007, 08:51 PM
mullenh's Avatar
ls6 flow better 5.3 has compression, same as putting the old 327 heads on a 350
