my lsat prostar question
I am getting prostars and wanted to make sure that i had everything on mny list i need
1. 15X10 rims with 7.5 backspacing
2. 325-50-15 mickey thompson drag radials
3. 15X4 rims up front with a 5/16 back spacing?? is that right?
4. i need to know the tire size that fits a 15X4 front tire and a brand you like.
and as far as the front tires i was thinking mickey thompson front runners- 22.5X4.5-15 (would that work ok?)
oh yeah i also need lug nuts, what size and brand would you recommend
Can you guys think of anything else i need? thanks
15x3.5 with 1.75" bs (only bs offered ont he 3.5s). You might be able to go with the 4" wheels with LT1 brakes, but the 3.5s would be easier to sell/trade down the road. 22" is too short on the front. I'd run a 26x7.50 Mickey T. Sportsman on the front. You'll need shank style lugnuts 12mmx1.5 I think. Don't get the Weld lugnuts, they will rust in no time.
Unless you're going to grind the front calipers you'll need 5/16 inch spacers for the front. I just installed draglites on my car and unless the prostars are different through the wheel hub you'll need longer studs especially for the front (3.25" long is what I used front and rear).
if i run a 4 inch tire do i still need the 5-16 spacer because honestly i was just looking at the new wheels that summit is putting out the look exactly like the prostars and are a lot cheaper. what do you guys think about those?
